What oil are you using in the Jerico DR4 Rev4 gearbox? And how much?
Any difference between oil brands? |
Liked 54 Times in 27 Posts
I have the regular DR4 and use Torco RTF. Jerico sells lube also.
Liked 24 Times in 13 Posts
I have the DR4,not rev 4.I have been using 75-90 synthetic, never a problem.
I have used Castrol in the past.I am using Royal Purple this year, for no particular reason.I fill till the oil can be seen in/at the fill hole. |
Redline light weight shockproof gear oil. 1 quart. Can pull cover off trans and still clinging to cover.
Liked 1,439 Times in 301 Posts
What he said!
James Schaechter 3163 STK |
I also use the Redline lightshock blue oil in my Jerico DR4s, and the pink Heavyshock in the rearend.
Like Jamie said, the stuff clings like crazy, I removed the cover after the car sat all winter, and the lube was still clinging to the top and sides. Good stuff.
Liked 13 Times in 7 Posts
How much lube are you guys running in a GM 12 bolt?
I use one liter(Canada eh) 75/90 synthetic in my 12 Bolt.
Same oil/lube as my DR4 |
