Old 02-25-2014, 08:47 AM   #1
1320pro
Default 67-70 Mustang 30x9 Tire Help
Hi Everyone,
Wondering if you guys had to modify your rear fenders to get the 29.5 tires to fit on your 67-70 Mustangs? If so how much did you have to shave off? The fender lips are cut on mine but the openings from and back are still stock. If anyone has any up close pictures that would be great.
Thanks!
1320pro is offline   Reply With Quote
Old 02-25-2014, 10:55 AM   #2
Rusty Gillis
Rusty Gillis's Avatar
Liked 87 Times in 19 Posts
Default Re: 67-70 Mustang 30x9 Tire Help
Originally Posted by 1320pro View Post
Hi Everyone,
Thanks!
Your wheel opening is only about 30.5" if it was mine I would want at least 32".
Rusty Gillis
Former NHRA SS/FA and SS/GA record holder
Rusty Gillis is offline   Reply With Quote
Old 02-25-2014, 01:59 PM   #3
Rory McNeil
Liked 1,112 Times in 304 Posts
To fit a 29 1/2" tall tire, you will defineatly need to cut a section out of the front section of the wheel opening, you may or may not have to cut the rear area as well, depending on how much clearance you are comfortable with, and if the tires are radial or bias.
NHRA 6390 STK
M/S 85 Mustang
Old 02-25-2014, 05:34 PM   #4
1320pro
Went and tried to measure what clearances I have. Car is in the corner of the garage so just rough estimates here. Right now I have a 28" slick on it. I appear to have 31.5" between the bottom of the rocker panel and the quarter drop off behind the tire. I appear to have 1.5" of clearance between the tire and the rocker panel in front and about 1.25" between the tire and the quarter panel drop off behind the tire.
Old 02-25-2014, 08:03 PM   #5
4284spd
4284spd's Avatar
This is a 29.5x10.5W on my 68. Thankfully its mini-tubbed. It still rubs in front and at the 2-3 o-clock position. On a stocker its worse because the tread and buldge are in the way.
Bob Smith
Old 02-25-2014, 10:34 PM   #6
1320pro
Thanks Bob.
Your car is awesome!
Old 02-26-2014, 08:55 AM   #7
Kirk Morgan
Liked 81 Times in 45 Posts
Wheel width will make a difference on tire fitment. Wider rim less bulge.
Kirk
Kirk Morgan is offline   Reply With Quote
Old 02-26-2014, 10:31 AM   #8
Liked 10,935 Times in 2,259 Posts
Don't forget to allow for tire growth going down the track.
Old 02-26-2014, 10:02 PM   #9
Mike Gray
Mike Gray's Avatar
Liked 705 Times in 204 Posts
9x29 Hoosiers on 10" rim without trimming, used a BFH to help them fit. There is more room in the front than the picture shows, should also fit okay once I have all the weight back in it.
Old 02-27-2014, 01:57 AM   #10
Geerhead55
Liked 5 Times in 5 Posts
Talking Re: 67-70 Mustang 30x9 Tire Help
Ahhh,, the trusty 'ol BFH. No tool box should be without it.
Danny Durham
