Old 02-12-2014, 04:35 PM   #1
KennyAnderson
Liked 359 Times in 120 Posts
Default Re: Project Pure Stock Debut
This is a 93 with OBD1 and a no E 4L60. The tranny has no electronic controls. It uses a governor like a TH350 etc. I'm hoping the manual VB feature of this shift kit fixes it. I like the idea of leaving it in drive but it seems to shift inconsistently and late. The reason I say this converter could be tighter is simply cause with the 3 sumptin low gear and 4.10's it really revs fast in 1st and goes thru the power band quick. I'm seat of the pants guessing but the power band seems to be around 4500-5500.
Got headers today too! Woohoo! Long story short, I'm whittling away at it and the car responded a ton to everything I've done. .5 under shouldnt be much trouble.
KennyAnderson is offline   Reply With Quote
Old 02-12-2014, 05:28 PM   #2
Ed Wright
Ed Wright's Avatar
If the rules allowed a different ratio trans it would be much more managble. That much low gear in a light car will keep you busy adjusting it. Mine was like a tractor. Spinning the tires or standing straight up. :-) The big RPM drops at shifts don't help anything.
Think tech would notice a metric 200? LOL
Ed Wright 4156 SS/JA
Old 02-12-2014, 06:32 PM   #3
KennyAnderson
I was thinking a TH350 with a 4L60E tranny pan welded on the bottom! LOL!
Old 02-12-2014, 09:24 PM   #4
Ed Wright
Ed Wright's Avatar
Does the Bullet "blueprint" cam keep factory duration? Is that even published? If it has more duration your RPM range will be higher. On-track testing I have done with both my bone stock virgin LT1 Camaro & TA (not even headers that would effect it) showed quickest ETs (with proper tuning) shifting it at 6000 RPM. I'm not sure what you are seeing on an chassis dyno sheet that tells you the needed stall speed. You do realize, that with an automatic car running a loose converter, the numbers are skewed (out of sync with the torque numbers), right?
Old 02-14-2014, 02:46 AM   #5
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Yes it is published.
The engine was dynoed by Jeff Warren after he built it.
Btw where do you have a dyno?
D
Old 02-14-2014, 09:26 AM   #6
Ed Wright
Ed Wright's Avatar
D
What duration does the published spec show?
The chassis dyno in my shop for fifteen years. I now dyno my SS engine on engine dynos at either Patterson Racing Engines or Morton's Machine.
Old 02-14-2014, 01:39 PM   #7
Dan Fahey
Dan Fahey's Avatar
Bullet Cams calls Mike Baker to confirm Duration.
Mine was easy because the NHRA/IHRA uses the F-Body Cam specs for B and F Body LT1s.
Where is Patterson and Morton?
D
Old 02-12-2014, 09:30 PM   #8
Ed Wright
Ed Wright's Avatar
Yeah, a Pro Trans. LOL
Old 02-12-2014, 05:38 PM   #9
Dan Fahey
Dan Fahey's Avatar
Install a Bullet Blueprint cam you will be fine....and very happy !!
Regarding 3.08 first gear on the 4L60.
On a heavy car like mine it just the ticket.
The factory cam power range, yup you are correct.. !!
d
