Old 02-08-2014, 01:13 PM   #1
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Is a Mexican Block Worth the Trouble?
I have the opportunity to pick up a 302 Mexican block for my Super Stock GT Mustang build. I've read that it's stronger than the stock 302 but with two bolt mains, not the BOSS four bolt. Would there be any fit issue with this on the bottom end for a Scat or Eagle crank? I intend to do a complete rebuild and I can sell my current engine outright if I buy a block.
Thanks for your time.
Dale
Dale Shearon
68 Mustang 6394
Old 02-08-2014, 02:17 PM   #2
Mark Ugrich
Liked 71 Times in 38 Posts
Default Re: Is a Mexican Block Worth the Trouble?
Cranks should drop right in.I'd fill the block to stabilize the cylinder walls and use it.
Old 02-08-2014, 02:54 PM   #3
Greg Hill
Liked 279 Times in 68 Posts
As much money as it costs to build a SS motor I would use a Boss block. You are probably going to be turning that thing 9,000 rpm. You will be money ahead with the best block you can buy.
Greg Hill 4171 STK
Old 02-08-2014, 03:57 PM   #4
FireSale
FireSale's Avatar
Thanks for the quick replies. My car will probably be SSGT/L to M Auto, and I don't think I can get 9000 rpm out of my first racer. BOSS would be the way to go, but they cost a lot. I can get the Mexican for around $300.
Dale
Dale Shearon
68 Mustang 6394
Old 02-08-2014, 04:23 PM   #5
Greg Hill
Dale
You're stepping over dollars to pick up dimes.
Greg Hill 4171 STK
Old 02-08-2014, 04:31 PM   #6
FireSale
FireSale's Avatar
I'm going to paint that on my garage wall. Kind of dumb to put $3000 in just heads and a rotating assembly on a stock block.
Dale
Dale Shearon
68 Mustang 6394
Old 02-08-2014, 04:52 PM   #7
Mark Ugrich
I agree a Boss block would be the way to go if you can afford it.The stock block deal has been done before too.
Old 02-08-2014, 05:27 PM   #8
Stephen & Horace Johnson
Liked 163 Times in 53 Posts
If you have the money get the boss block it's alot better than the stock block..but I know a few SBF guys that are running the stock block with no issues in SS.. I would def put hard block in it. I have a Mexican block in my mustang and has run some 10.30s...with a stickshift at 7400rpms..
Stephen Johnson #2162
Horace Johnson #2167
Stephen & Horace Johnson is online now   Reply With Quote
Old 02-08-2014, 06:13 PM   #9
randy wilson
Liked 22 Times in 22 Posts
I don't know about filling a Ford block, but I've filled three GM 283, and 327, and 350 blocks in my life. I would NEVER fill a block. Every time we've done it, when you get ready to re-hone, the chatter from the stones going down in an oblong bore, is deafening. They NEVER stay round. On the other hand, when not using filler, the block was WAY straighter. And yes, we use a plate.
don,t have one
Old 02-08-2014, 06:32 PM   #10
BillK
Liked 30 Times in 17 Posts
Randy,
Curious as to what you filled the block with ? I had the same experience years ago with a block I did for a customer that he had filled. He used one brand of filler that I had never used and his block did move around a lot on the first freshen-up and a little bit the second time.
I have always used Hard Block and have never had it move around ?
Bill Koustenis
BillK is offline   Reply With Quote
