Old 01-30-2014, 11:53 PM   #1
4spdJohnny
Liked 137 Times in 46 Posts
Cool Re: 1965 Malibu Wagon build
Looking very cool Charlie!
John A. McLaughlin
5757 B/S 440-6 or G/S 383 70 Road Runner, Dad's
5096 K/SA 70 Two Ton Tamater, Taylor's,Alec,Breezy
4spdJohnny is offline   Reply With Quote
Old 02-03-2014, 10:18 PM   #2
Charlie Berner
Charlie Berner's Avatar
Liked 8 Times in 2 Posts
Default Re: 1965 Malibu Wagon build
wet sanding and buffing and parts going on day 28. more part coming tomorrow..
Charlie Berner is offline   Reply With Quote
Old 03-02-2014, 12:13 PM   #3
doug schriener
Liked 7 Times in 6 Posts
Hi-Nice car!!!!! Go out and have fun with it. I ran a 64 for 10 years ;not a world beater but learned a lot from it. Doug Schriener
doug schriener is offline   Reply With Quote
Old 03-05-2014, 10:59 PM   #4
Charlie Berner
I still waiting on parts. We going to get working. Soon! I have been chasing rear end stuff. Thought I had a plan for the 10 bolt but they don't make 5.13 gears any more for a 8.2 . (Thanks Obama) stock rear in this car! So 12 bolts from moser are 2400 bucks! Find a factory 12 bolt for a 65 ya right! So we found a 10 bolt 8.5 rear from a 1973 and up. But I live in South Dakota in the coldest flippin winter in the history of the planet ( Global warming ya sure Al Gore) So the car with the rear end I need is stuck in a snow pile. Nice! New Bullet cam on the way! Disk Brakes for front on the way and all the front end stuff. So next week guys I will have more pictures. Oh by the way I need more sales to finish this thing! So check out my website midwestracecabinets.com
Old 03-05-2014, 11:33 PM   #5
FED 387
Liked 333 Times in 180 Posts
chrlie berner sent u a pm--FED387
Old 03-06-2014, 02:17 PM   #6
Harry 6674
How about taking the brackets off you rear and welding them on a narrowed big car 12bolt rear end. Easy way to get around those hard to find rear ends. That's if you feel you need the extra strength.
Harry 6674 is offline   Reply With Quote
Old 03-06-2014, 04:03 PM   #7
Lyn Smith
Liked 984 Times in 198 Posts
I could be wrong but that 73 8.5 is going to need alot of work before it bolts into a early A body.Got be at least 2 inches too wide on each side.And i think the upper control arms are at a different angle also.
Old 03-06-2014, 07:59 PM   #8
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
Big car 12 bolt does not have the ears on the center section for the upper control arms. An 8.5 Grand National/442 rear will fit with some work (Upper control arms are wrong angle and you will have to use lower brackets off your 10 bolt.). '73 up A-body 8.5 takes more work than that.
Old 03-06-2014, 11:32 PM   #9
Charlie Berner
Nothing is easy! I thought they were the same but just wider. Crap Well dont need to dig that out of the snow! I put the new grill in tonight (repo crap) fit like ***** so i looked at the box made in Taiwan .. Got to love your vintage chevy made with over seas parts.... Again thank Obama... Whats the world coming too!!! The front seat is recovered, wanting of the rear seat cover yet. UPS will be at the shop tomorrow! Thanks everybody for the input thats what make class racing fun..
Name:	chevelle grill4.jpg
ID:	23026   Click image for larger version
Name:	chevelle grill3.jpg
ID:	23027   Click image for larger version
Name:	wagon grill.jpg
Name:	wagon grill2.jpg
Old 03-11-2014, 12:02 AM   #10
Greg Reimer 7376
Liked 705 Times in 219 Posts
Question Re: 1965 Malibu Wagon build
I think on your wagon, since you have been presented several unattractive options, instead, use a '68 to '72 Chevelle 12 bolt. It's about two inches or so wider, that can be compensated for by rim selection, and if you want to put good axles in it and a C clip eliminator kit, the flange width can be adjusted then by whoever does your housing work. What is a rare item, but might be found also, is a '72 Chevelle 8.5 inch 10 bolt. I'm not too sure what those came in, but don't confuse it with the 73-77 unit. It won't be easy to find,however. At least the 68-72 12 bolt will be a bolt in under that car.Good luck on what looks like a fun project!
