Same here. Just thought it was my phone. I've closed out the sight (class racer) and even restarted the phone. No difference. Very frustrating.
Jeremy Erny |
Same problem I downloaded CSR classics racing game and it started after that, thought it might be the problem deleted it but still happens, iPhone also
Liked 3,181 Times in 972 Posts
On the iPhone you can go to 'settings' 'safari' (assuming you're using the default browser) and can select "Block Pop-ups" or depending on the intrusion you may have to go all the way down to 'advanced' under 'safari' and disable JavaScript but it's likely you'll have to turn it back on occasionally to display things you want to see. All this is using the iPhone 5 with IOS 7, older phones/software may vary slightly.
Face it, the 'free' internet isn't free anymore.
I have the IPhone 4S running IOS 7.0.4 - block pop ups on and still having an issue. Not sure if there is a fix CR can do. Only seems to happen to this site. DRC & other sites dont seem to have this issue.
Jeremy Erny |
Sponsor
Liked 218 Times in 61 Posts
I just started having the same problem on my iphone. I have tried turning the phone off and on but still happening. I'm sure there must be a simple fix but I will be glad to know what it is.
Administrator
Liked 587 Times in 35 Posts
I'm not seeing a problem on my end, but I shut down the google and digital throttle advertising to see if stops the pop ups.
Let me know if you are still having issues. Ken
Administrator Class Racer.com |
My iPhone has been doing it last three days. Not just here. Does not do it on Facebook for some reason. I have the pop up blocker on.
Ed Wright 4156 SS/JA |
Liked 1,583 Times in 582 Posts
Download Malwarebytes and AVG Cleaner and it will peek those pesky apps out.
