#41 | |
Liked 9 Times in 3 Posts
Mark Markow 171 ss/tb |
#42 |
Liked 100 Times in 51 Posts
3M Adhesive Remover works great, and the plastic razor blades are a big help. Autozone, Orielly's has it on the shelf......
#43 |
Liked 263 Times in 68 Posts
Should you drink the beer for several days before you start?. Just wondering!
John Dinkel 3295 STK |
#44 |
Liked 124 Times in 39 Posts
Angelo, go to the automotive paint supply store and purchase the die grinder with eraser wheel attachment. Astro tools sells the product. You will need a couple eraser wheels to remove a lot of decals. The wheel is a four inch eraser, and it works great.
Sean Cour T6066 ladle |
#45 | |
Liked 282 Times in 103 Posts
3M Adhesive Eraser Wheel Part No. 3612 |
#46 | |
#47 |
I've never had a problem getting them off with just a heat gun. I get the glue off with Safety Kleen parts washing solvent, it won't bother the paint. Never had to use anything else.
Ed Wright 4156 SS/JA |
#48 |
Liked 1,883 Times in 578 Posts
heat gun for the bigger ones, get heat just right glue will come with it. any glue residue use wd 40. wont hurt paint at all. for the small or multiple letters or very thin vinyl use the eraser wheel. this combo can get an entire cars decals off in under an hour.
#49 |
^^^This..... much better/faster than WD40. Also works great on removing the rubber from your rear rockers.
Jerry Williams NSS/A, E/S, PRO E.T. And the "Grandaddy" of Gen III Hemi Performance...The fire inside me still burn's. |
#50 |
Parts washer solvent works well for both also. Just dip a rag in your parts washer if you don't feel like driving to the auto parts store.
