#1 | |
Liked 13 Times in 9 Posts
Yes. Although a 2" cone would be better. The concept of coupling restrictions on both the intake (restrictor plate) and exhaust (collector) massively mitigates any gains from trying to work the carb, cylinder heads, etc, because it can't breathe. It's not worth spending money on a no-gain proposition. If you used this method, you wouldn't *need* a spec head. Install the plate and collector on any combination, and go play. Tech is a breeze.
We did extensive computer modeling of this concept, ending up with everything from 350 small blocks to 540 big blocks running within less than a tenth of each other. Some ran the first half of the track better, and some ran the back half better, but it all came out in the wash. You can make weight break adjustments for different transmission types, body styles, or whatever you find out is necessary. Quote:
Liked 22 Times in 22 Posts
Ok, I'm confused. Am I to believe that a 461X head unported, with tall valves, and big springs will run with a 15 degree done by Reher and Morrison? Someone needs to tell the Nascar guys, they're spending WAY to many $ on heads in the restrictor plate classes. They don't know a stock vortec will do the same thing, and only cost $800.
don,t have one |
#3 | |
Liked 7,732 Times in 1,739 Posts
#4 | |
Liked 18 Times in 12 Posts
Has anyone done some real world testing of this on some drag cars? I'm curious. If I understand what your stating, in theory, we should be able to pick 20 cars, equip each with a single 4 barrel carb, install the 1" carb plate and the 2" header collector and have a group of cars that should E.T. with in approximately 0.10 of one another.
"Real Race Cars Have Tailgates" |
I'm curious too. Did they all weigh the same, as in lbs. per cubic inch?
don,t have one |
#6 | |
Liked 32 Times in 19 Posts
Billy very good point. Probably will take a few test and tune runs for jetting etc . Only difference is the guys will still have the 20K + motors when all is said and done but it would allow a test of the theory.
Dick, by restricting the intake AND the exhaust you take away the need for that 20K + motor. It may even become a hinderance as your big cam and heads are going to cause reversion issues at some point, something that you don't need with a restricted intake. I believe that cylinder pressure, gearing and an overall ability to tune the combo will be the major factor. I also believe that you would wind up with two totally different schools of thought in the long run, big, torque monster dump truck motors and smaller well tuned and higher winding modified type motors.
#9 | |
As for monster truck motor remember the lb per cubic inch idea. No more 9 passenger wagons on steroids. I am with Randy and many others it may never happen that an organization will decide to limit these specs BUT... just heard power boat racing has now developed a sealed or spec motor class. It has worked till now the guys are spending the money on trick hull for advantages. Maybe if IHRA made any noise about it NHRA would do it to out do them. |
Check into the APBA and let me know what you think then. They're hurting so badly for participants that they, on occasion, have to cancel races.
