Old 01-02-2014, 09:08 PM   #1
Default Re: Econo Modified
Originally Posted by Glenn Hayes View Post
Make the Class with 4 & 5 speeds only.
Much as I would like to see a bunch of old Modified cars with stick shifts, if you make it clutch cars only, you will restrict the available car count.
This isn't just going to be a bunch of youngsters either, that would want to be changing clutches and transmission gear ratios all the time.
Whatever you end up with for engine rules, make it autos allowed, but no weight break.
Only other thing I see is delineating the newer aero cars from the old.
There isn't an exact year where it all started, so maybe a weight break for longer wheelbase.
You wouldn't need a big weight difference to correct anything ,with cu. in. / weight and a spec head motor.
Old 01-02-2014, 09:12 PM   #2
randy wilson
Liked 22 Times in 22 Posts
Mark, what year of car would start carrying the wt? Serious question. Another serious question. Is there an advantage from clutching, and shifting a 5 speed, and say, a trick 200 metric?
don,t have one
Old 01-02-2014, 09:18 PM   #3
Ed Wright
Ed Wright's Avatar
The stick cars do bigger wheel stands?
Ed Wright 4156 SS/JA
Old 01-02-2014, 09:29 PM   #4
Don't know ..That's why I said use wb maybe.
Have to look at the common cars out there..
Maybe under 108 , as is
108 -114 take out 50 lbs.
115 or more, (Tri Five Chevies) take out 100.
If you look at S/SS cars..ET's as good or better with automatics.
MPH usually higher with stick shifts... Simple physics there..although high rpm motors can couple a converter up more, but not 100%...unless of course you allow lock up converters LOL
Old 01-02-2014, 09:41 PM   #5
randy wilson
Thanks Mark.That helps.
don,t have one
Old 01-02-2014, 09:32 PM   #6
Glenn Hayes
Glenn Hayes's Avatar
Liked 18 Times in 12 Posts
One thing that you need to keep in mind:
The NHRA has turned it's back on Sportsman racing for many reasons, but I believe they no longer want to deal with trying to enforce and regulate engine rules. This requires way to much time, man power, etc which equals money.
Look around, the Pro Mod, 10.5 Tire Classes, Top Sportsman, etc are thriving do to basically allowing you to show up with what ever combination you can dream up, and as long as you meet the minimum weight and have the correct tire, your good to go.
We all know why Super Street, Super Gas and Super Comp have flourished over the past 25 years, same reason, run what ever you want and don't break out. Where they went wrong in my opinion was allowing electronics and throttle controls. Take all of that away and put it back in the drivers seat and see what happens!
If your going to start a new class, one must learn from the failures of years and classes gone by. I, like many of you have been there through all of this over the past 40+ years and that's why this discussion is taking place.
Old 01-02-2014, 09:39 PM   #7
randy wilson
Glen, you can't put lipstick on a pig, and call it a goat. Bracket racing, for ALL it's participation, has ZERO crowd appeal. And one way spec might work, is like I've stated, winners, runnerups, and record breakers pull a head, and we, the racers seal the box, ship it in with the owners return address, and let Brodix make the call. I'm sure for a small fee, they would be happy to do it. Also, have 5 designated racers police the class. I already said I'd furnish the fuel check equipment, and the P&G gauge. And no, it don't have to be me policing it. There's several I, and others would trust.
don,t have one
Old 01-02-2014, 10:02 PM   #8
Adger Smith
Liked 880 Times in 311 Posts
Let the racers pay a small fee and hire Wesley to be independent from NHRA as Tech. He is available. He also makes & implements the rules for EMC. It is set up where He is the final say on Tech.
No reason an independent class couldn't be set up the same way.
There are lots of possibilities. Pro Mod has already opened the gate for classes that are run independent from the mainstream NHRA classes.
With the right set of rules and a good enough show the program could be sold to smaller regional/local tracks. For something like that to work you have to remember it has to have crowd appeal so the track owner can draw spectators. That is a must.!! In today's markets that is a 180 departure from how a lot of local tracks make money. A program like this will not draw enough racers for a track owner to make it profitable by the draw off the racers only.
Adger Smith (Former SS)
Old 01-02-2014, 10:04 PM   #9
Glenn Hayes
Randy,
I get it, trust me, but where does developing another "Class Car" bring back the spectator? They don't even watch Pro Stock!
Heads Up, pounds per Cubic Inch racing was always great to watch. I've been to Bethany, even raced there a few times in the late '70's. I've been to every NHRA national track event in the country, and almost every divisional event track dozens of times. I worked for a major racing sponsor.
There are small groups all around the country that are having some success with their specific styles of cars, The Super Shifters, The East Coast Gassers, The Southeast Gasser Association, as others. These are not NHRA or IHRA classes, and the area track or tracks that love them and embrace them with support do so because they bring in a crowd.
This "Style" of racing is what is bring folks back to the drag strip: [ame="http://www.youtube.com/watch?v=av0xgcchv18"]CPTV - THE ANATOMY OF A RIVALRY - YouTube[/ame]
Old 01-02-2014, 10:22 PM   #10
randy wilson
Glen, this is just my opinion, so let me try to explain it. I grew up doing just no break out racing, so everyone knows where I'm coming from. When it was going, they averaged 1,000 spectators a night. And have had as many as 1,500. I ran at Eddyville in the 70's. They had standing room only, and 64 car fields in SS, and Top Street, (Comp) and turned away 86 cars the first time I entered. I was one. I did not qualify. The bump was .34 under. I went back when they started bracket racing. About 30 spectators. That's what we're missing, and I think it is over. I am quitting this year. Last year was my, and Steve Thompson's last. This just piqued my interest enough to stick around. Do I know it will work? No! Do I hope someone higher up sees the opportunity? Yes! Do I think they will? No! But it is fun to dream.
don,t have one
