Old 01-01-2014, 03:30 PM   #18
hadtobethere
Default Re: Nova stocker project.
Geez Bob....that things about the size of the crankshaft in my 327! Reminds me of the 'rubber' Stocker camshaft designed by (blank blank). The lobes grew as the RPM's went up! -Al
Al, after a bit of forward thinking....most likely Stock will expand the rules, so you should be ahead of this...
It will be hard to put one of Steve's BB in that thing and call it a 327 so....Ya, Sherwood can get the 'Shadow' to work a big stick to fit, and that old Nitro kit from the Pro guy will work fine. DB has a crate motor on order that you can use. Check and see if old Northwind has a valve train, also W.S. has some parts....more later.
hadtobethere is offline   Reply With Quote
