Old 12-27-2013, 08:52 PM   #1
jimmyparker
Liked 309 Times in 88 Posts
Default 1975 Index System
Attached is copy of index system used in the mid seventies, when I mention this system I always get a blank stare as no one seems to remember it . Play with the math based on todays et's for various classes and it is scary.
Jimmy Parker
jimmyparker is offline   Reply With Quote
Old 12-27-2013, 08:55 PM   #2
jimmyparker
Default Re: 1975 Index System
I see the attachment didn't take, I'll try again later or if someone else has it copied feel free to post.
Jimmy Parker
Old 12-27-2013, 09:39 PM   #3
Ed Wright
Ed Wright's Avatar
Jimmy I remember when they went into effect. I started running C/SM the year they started that. We could only run one tenth under, no dialing down.
Ed Wright 4156 SS/JA
Old 12-27-2013, 10:29 PM   #4
GRAPE
They called it a Par System. All class's had a 3 didget index. C/S was 4.27 C/SA 4.46
The C/SA car would get a .19 head start. First car to finish line would win .they did this so that any car could run against any other car. A/D index was 0.00 would give 4.27 head start to C/S. A /D Record was 7.50. If you add 7.50 to 4.27 =11.77 that was the ET a competeive
C/S should run.The C/S record was 11.72
GRAPE is offline   Reply With Quote
Old 12-27-2013, 10:48 PM   #5
Bill Diehl
Bill Diehl's Avatar
Liked 9 Times in 8 Posts
Who would like to see it that way today?
Bill Diehl is offline   Reply With Quote
Old 12-28-2013, 01:09 AM   #6
Liked 5,121 Times in 1,952 Posts
Probably a lot more fans..than racers.
