Liked 50 Times in 23 Posts
From the 2014 IHRA Rule Book... Pure Stock lost a little "Purity" today .. This is posted for the guys who might have a cam on order or will be soon..
12/10/13 p. 48 Pure Stock: Camshaft: Camshaft must retain stock lift for horsepower claimed per IHRA Technical Bulletins. OEM duration and overlap is optional Can't get too crazy as the valve springs still have to check at OEM pressures, open and closed. Guess this was changed to speed up tech / tear down or maybe lack of data supplied by the OEM's?
Steve Stickel 1161 Stk 1167 SS |
#2 | |
Guest
Posts: n/a
Liked 228 Times in 70 Posts
Sounds like 10 second pure stock cars are just around the corner!
#4 | |
Liked 184 Times in 113 Posts
OK.. emailed Mike Baker ..and it is true. Can use any OEM Spring. This is Mike's response to my email.. "If it is oem design and size it is ok" D Last edited by Dan Fahey; 12-17-2013 at 04:32 PM. |
Liked 33 Times in 16 Posts
I think it means they didnt want to copy/paste the NHRA rulebook for Stock...not a bad idea in itself.
Rich Taylor I/SA - 321 |
Liked 986 Times in 198 Posts
I can finally retire my General Kinetics special Pontiac lobe(thats what they called it even though it was in a Buick) stock duration cam i had made in 1980 .I think i will mount it on a board and put it on the wall in the man cave.LOL
Liked 16 Times in 11 Posts
I know one that will go 10s 67 vette 427- 400 for sure.
Bob Pagano A/SA |
Do you think the IHRA just cracked open their version of Pandora's box by loosening the camshaft rules ?
Liked 372 Times in 130 Posts
Holy Cow !
As an owner of a Pure Stocker, I'm not sure if that is good or bad ? Thanks for posting that.
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
#10 | |
Am I reading this correctly ? ANY valve spring can be used (regardless of measured pressure) as long as it looks OEM ?
