Old 12-17-2013, 05:37 PM   #1
FINESPLINE
FINESPLINE's Avatar
Default Re: Pure Stockers New Camshaft Rule !!!
Do you think the IHRA just cracked open their version of Pandora's box by loosening the camshaft rules ?
FINESPLINE is offline   Reply With Quote
Old 12-17-2013, 09:34 PM   #2
The Hawk
The Hawk's Avatar
Liked 249 Times in 109 Posts
Originally Posted by Lyn Smith View Post
I can finally retire my General Kinetics special Pontiac lobe(thats what they called it even though it was in a Buick) stock duration cam i had made in 1980 .I think i will mount it on a board and put it on the wall in the man cave.LOL
I love that idea!!!
Lane Weber
Old 12-17-2013, 10:10 PM   #3
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Wink Re: Pure Stockers New Camshaft Rule !!!
I'm thinkin' the indexes will need to be adjusted now. Jim
Old 12-17-2013, 07:11 PM   #4
ALMACK
ALMACK's Avatar
Liked 373 Times in 131 Posts
What does OEM duration and overlap optional mean?
OK.. emailed Mike Baker ..and it is true.
Can use any OEM Spring.
This is Mike's response to my email..
"If it is oem design and size it is ok"
D
Dan:
Am I reading this correctly ?
ANY valve spring can be used (regardless of measured pressure) as long as it looks OEM ?
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 12-17-2013, 07:36 PM   #5
Rick Schilling
Liked 14 Times in 10 Posts
Originally Posted by ALMACK View Post
Dan:
I'm seeing the new cam rule in the 2014 rule book but it still reads the same as before for the springs.
Maybe it just hasn't made it into print yet but I'm going to wait until I see it in black and white.
Rick Schilling is offline   Reply With Quote
Old 12-17-2013, 07:50 PM   #6
Steve Stickel
Steve Stickel's Avatar
Liked 50 Times in 23 Posts
[QUOTE=Dan Fahey;412873]What does OEM duration and overlap optional mean?
"If it is oem design and size it is ok" QUOTE
Better get that in writing or amend it in the rule book cause look at page 49 2014 rule book,
VALVE SPRINGS:
Stock replacement per OEM spec. and must check on factory spec.
open and closed pressure
Pandora's Box
Steve Stickel
1161 Stk
1167 SS
Steve Stickel is offline   Reply With Quote
Old 12-18-2013, 11:39 AM   #7
Dwight Southerland
Dwight Southerland's Avatar
Liked 784 Times in 196 Posts
D
You better get clarification on what Mike says. "If it is oem design and size it is ok" says nothing definitive about pressure.
Old 12-18-2013, 12:09 PM   #8
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Here are the emails back and forth from Mike last night!
Sent: Tuesday, December 17, 2013 3:33 PM
To: Daniel Fahey
Subject: Re: Pure Stock Spring VS574 - Checking for Legality
Yes
Sent from my Verizon Wireless 4G LTE DROID
Daniel Fahey wrote:
So if the Spring Pressure is 30% above Stock it will be OK?
Just so long as it is a Stock Replacement Spring!
Correct?
D
Daniel Fahey - CEO President
DanSources Technical Services, Inc.
1010 Rockville Pike, Suite 405
Rockville, MD 20852
301-217-0425 x 400
www.DanSources.com
Sent: Tuesday, December 17, 2013 3:25 PM
To: Daniel Fahey
Daniel Fahey wrote:
Hello Mike:
Called Bullet Cams for advice…
He asked me to confirm on my LT1 1995 SBC Engine.
My Car runs G/Pure Stock. 1995 Impala SS.
Looking at a replacement spring from Associated Spring VS574..
Lists as a LT-1 replacement spring.
Need to know if it qualifies as a Pure Stock Legal Spring for my car.
Dan
Rockville, MD 20852
301-217-0425 x 400
www.DanSources.com
Old 12-18-2013, 12:13 PM   #9
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Keep in mind a email assurance does not hold the sway of a rulebook. Tech inspectors do not carry copies of emails.
"Stock replacement per OEM spec. and must check on factory spec. open and closed pressure."
Rich Taylor
I/SA - 321
Old 12-18-2013, 12:31 PM   #10
Dan Fahey
Dan Fahey's Avatar
YES..just sent him another email asking that question.
As for 10 Second Pure Stockers.
Here is a link of the first 9 Second ET in Stock history.
Bobby DeArmond...May 9, 2001
http://www.nhra.net/fedmog/2001/news/may/050901.html
Dan
D
