Liked 5 Times in 5 Posts
If your collectors bolt on.to the headers with tabs are you still required to use the tethers? Thanks
Liked 100 Times in 51 Posts
Only way you DO NOT need tethers is if you weld the collectors to the tubes. I believe the rule says you need at least a 1" stitch on at least 2 tubes but I could be off on that.
Liked 544 Times in 213 Posts
1/2" weld per tube......I just did mine and tig welded them a lot more than that.
They needed recoating anyway and I also added a weld bung for O2.... Now I need a big box to ship them in.....
