Liked 11 Times in 1 Post
Its a 4000lb car with 4.88 gears in it
I would try a different carb. You carb may be seriouslly lean at Sea Level.
Thats what other people told me as well. I wondered if it could be a fuel supply issue it does have a q-jet on it.
Liked 10 Times in 1 Post
Don't touch it ! How much you want for it ....
Billy Leber 1150 SS, 1050 SG, 1962 STK, 185 SC |
Liked 4 Times in 3 Posts
Doesn't, NHRA have a 12.00 HEADS UP CLASS NOW? So the way I see it NO PROBLEM
Alex Denysenko NHRA 3038 SS, 3305 STK - IHRA 6 SS, 330A STK Moneymaker Racing LaPorte Indiana 219-861-1214 www.moneymakerracing.net |
Liked 2 Times in 2 Posts
I would look at your fuel supply. I would say you are lean in good air. Just a guess.
Kris Rachford 69 Cobra 428CJ 4 Speed C/S 3032 |
Liked 13 Times in 7 Posts
I had a carb that performed like this. What fuel pump do you use? Change carbs if that doesn't help then upgrade fuel pump and/or regulator.
Richard Grant 4988 STK |
Liked 280 Times in 139 Posts
I've heard of people having problems with BG pumps. Otherwise, the system sounds ok.
