A friend is needing help in obtaining the correct width and back space sizes, for the Rear of his 2001 Camaro...
The car has an o.e.m. width Moser 12 bolt conversion... And he'd like to run as wide a wheel as possible that fits within the o.e.m. wheel house and the width of the axle. Any info is appreciated. Thank You!!
Larry Fulton |
Liked 660 Times in 187 Posts
Larry on a stock width rear a 15x10 with 7.5 backspacing is very common. I had a 15x10 with 8 inch backspacing that tucked it in a tad more and looked great. In the 8 inch backspacing wheel, it would have to be a bogart or holeshot wheel to get that specific 1/2 inch increment backspacing. Where 7.5 backspace is common on any wheel
Tim.
5664 GHI/SA 1985 CAMARO RED H/SA 1985 CAMARO BLUE I/SA |
Is the wheel you are describing this wheel, in the photos...
the front space looks Deeper than what you are describing? btw - Good Looking Car!!
Larry Fulton |
Liked 56 Times in 31 Posts
I run Billet Specialties Street Lites, 15x10 with a 7.5" backspacing.
Billet Specialties makes these specifically to fit the 4th generation F-Bodies. This is on a stock rear end. |
What is the weight on those Billet Specialties?
Bill Lent O/SA 3158 |
Their website does not specify the weight.
You may want to contact their Customer Service Department. 800.245.5382 |
I ran weld rt-s 15x10 with 7.5 backspacing it fits really good I did have to bfh a little bit on the inside of the wheel well for the tire
Liked 5 Times in 5 Posts
