Old 10-25-2013, 11:12 AM   #1
Default Re: Richmond Pro gear alert heads-up...
For the vast majority of OE 12 bolt housings, start with a 0.035" shim on the pinion. Odds are, you'll be within 0.005" of where you need to be. If you're taking a similar gear out, use the shim from the previous pinion, and you'll be within spitting distance.
The numbers they give you are the opinions of the guy running the Gleason machine they test the gears on. What matters is the pattern.
And yeah, unfortunately, Richmond hasn't been great lately, and Motive buying them is quite unlikely to improve that.
Old 10-25-2013, 11:34 AM   #2
Ed Wright
Ed Wright's Avatar
A rear pinion bearing honed out to a slip fit would be handy for finding the correct pattern. I've heard of them. I've never seen one.
Ed Wright 4156 SS/JA
Old 10-25-2013, 11:50 AM   #3
Tod Lane
Tod Lane's Avatar
Liked 2 Times in 2 Posts
We made ours because we do so many in my shop. The RAYTECH tool is a big help too.
http://www.ratechmfg.com/toc.htm
Talk to Mary there.
Don't work for them, have used them and I am just passing along the info
Tod Lane
Swartz & Lane 66 Nova
Swartz & Lane 79 H/CM Trans Am
Tod Lane is offline   Reply With Quote
Old 10-25-2013, 12:01 PM   #4
Ed Wright
Ed Wright's Avatar
Thanks Todd! I have an old Zoom Gear set up tool. (Bought it new, I'm old) Never tried to hone one myself. I think they used to sell them, but never found one to buy.
Old 10-25-2013, 12:28 PM   #5
James Sessoms
The pinion set up tool that T&D makes is probably the best tool you can get. With the information that is provided with the tool you can figure all the necessary dimentions in the pinion set up process with no information from the gear manufacture. Now most of the readers of this site are going to be using a 10 bolt or 12 bolt gm, 9" ford or a Dana. All of these styles of rear ends are supported by this tool. If you get into a 10.25 or 10.50 sterling housing which can be found in most of your Ford F250 pickups I have found no one makes a set up tool or a pinion bearing pulling tool for these rears. Randys ring and pinion, Raytech and some other companies sell a set up pinion bearing that is honed out so you can set the pinion up by trial and error and not damaging the bearing by pressing it on and trying to remove it. What I have found with the gear manufactures most of this stuff is comming from over seas, CHINA, and the tolerances and spec suck. I know everyone remembers the chile Goodyear tires. When you get a new gear check, check, check every dimention in the protduct that you are getting. Just my 2 cents worth. Good luck
James Sessoms 2444 S/G
James Sessoms is offline   Reply With Quote
Old 10-25-2013, 01:51 PM   #6
Run to Rund
Liked 54 Times in 27 Posts
I have had good results with Motive gears made in Italy. This scribing error may not be such a big deal--I can't imagine someone setting up gears and not bothering to check the pattern. The Richmond tooling was worn out so Motive decided to go with their Italian supplier for both brands after buying Richmond.
An auto machine shop with a connecting rod rebuilding hone can easily open the ID of a bearing to use as a slip fit trial pinion bearing.
Old 10-25-2013, 05:23 PM   #7
tim worner
Liked 126 Times in 20 Posts
May be they will be available at Poppa Johns with any full size pizza.
Tim Worner SS 1747
tim worner is offline   Reply With Quote
Old 10-25-2013, 07:52 PM   #8
Tod Lane
Tod Lane's Avatar
I have had the same experience. We use some Italian made gears in heavy duty stuff that run fine.
Tod Lane
Old 10-27-2013, 10:26 AM   #9
Paul Merolla
Paul Merolla's Avatar
Liked 293 Times in 65 Posts
Talk to Mary there.
Good info, Tod - I wish I had heard of them before I did my 12-bolt. What about their "Smart Sleeve?" They say duty cycle is better than a spacer and shims. http://www.ratechmfg.com/smart%20sleeve.htm
That would eliminate the idea of honing a bearing.
As a side note, I bought used gears when I was putting the car together. When I went to press the pinion bearing on, it just slid over by hand. Turns out the previous owner's setup guy takes a little off all his pinions to make setup easier. A few people predicted disaster at the time, but after 60 or so runs this year the oil came out clean and the pattern looks great.
Paul Merolla is offline   Reply With Quote
Old 10-27-2013, 11:06 PM   #10
Tod Lane
Tod Lane's Avatar
We pretty much use the smart sleeve and pitch the regular crush sleeves or shim and spacers in most applications. MUCH easier to set preload than the old style crush sleeve.
Alot of their stuff is made there in cincy and pricing is good.
Tod Lane
