Hey guys,
Got a screw in the centre of one of the slicks, we currently run them tubeless and I was gonna just put a plug in it and good to go but..... Any of you guys plugged a slick before? Something I got no experience with. Thanks Geoff |
Liked 759 Times in 379 Posts
I have never run tubes and been plugging slicks and front runners for over 2 decades without issue. The best plug kit by far is this one...
![]() Last edited by 1320racer; 10-23-2013 at 07:59 AM. |
Liked 13 Times in 3 Posts
I as well have plugged slicks in the past without any problems
Chuck |
Liked 282 Times in 103 Posts
I don't race a Super Comp or Super Gas car,but if I had this problem,I would be getting new slicks.I wouldn't take the chance,but that is just me.
Liked 6 Times in 5 Posts
I have mounted 100s of slicks.If you use the sticky plug it will work fine.I ran one on a s/g car for 10 races.
Super glue works the best
Joe Demarais SS |
Liked 30 Times in 19 Posts
This is by no means a personal recommendation but at the Chevrolet-
Toyota dealership where I work we use a Tech brand repair system wherebye the tire is dismounted, the inner carcass is prepped and buffed and a large "mushroom" patch-plug is applied from the inside along with a special sealant. We have never had an issue with these as it is impossible for the patch to come loose. Of course I would never plug a tire tread close to the sidewall. Check dealers in your area. http://www.techtirerepairs.com/
.............................The older I get....The faster I was |
The inner carcass of a passenger car tire and that of a slick are not the same. Try prepping/buffing the inner carcass of a slick and you are quickly into the cords with no rubber left to bond the patch to. Further, a passenger tire does not go out of round as a drag slick does on acceleration which would allow the patch to deform and likely lead to failure IF you were sucessfull getting the patch to bond to the carcass. Vulcanizing is the right fix but cost prohibitted if it could even be done to a slick.
Me, I'll continue to plug slicks and front runners at the track/in the lanes, when the need arises, in minutes, ensuring I don't miss a round. Last edited by 1320racer; 10-23-2013 at 02:00 PM. |
Point taken, The "tread" area of a slick is very thin. I thought a
"mushroom patch" from the inside would be safer but the patch area on a slick would deform massively more than on a street tire.
Liked 56 Times in 27 Posts
Geoff,
Put a plug in it & be done with it , have been doing it for years without a problem .. *Only works when leak is in bottom surface ,not on side-walls !!! Plugs also work very well on Trailer tires .... Go for it, buy a Kit and always be prepared ...
Dave Ribeiro 1033 STK |
