I have 28 inch tall tires and a 4.30 gear and I want to put 29.5 radials on my 318 duster would this affect my e.t. and mph? and what gear should I have in it for the bigger tires?
Just looking at tire size/gear ratios, the closest to what you have now would be a 4.56 gear. As far as the et and mph, you have to look at the power curve of your engine and the rpm you want to cross the finish line.
Liked 308 Times in 103 Posts
MPH X Gear ratio X 336 divided by tire height = RPM . you can calculate difference and figure what you need to get rpm you want.
Auto will be slightly higher depending on % of converter slip,can also determine how good converter is working roughly anyway. Stick will come out just about dead on calculation. Mike Taylor 3601 |
Liked 13 Times in 7 Posts
Try this formula 26.4/28= ? X your gear = actual ratio.
My wording may not be correct, but whatever. What is your stroke, vehicle weight and 1st gear ratio?
N/A |
Liked 535 Times in 110 Posts
Don't forget that radials do not grow.
Jim Kaekel 3836 STK |
Liked 759 Times in 379 Posts
when comparing like size slicks, radials will increase your trap RPM by 200-300.
thanks for the help i want to try the 29.5 radials with a 4.88 gear
