Old 09-10-2007, 03:18 PM   #1
Inquiring Mind
Default Re: Richardson Barone, winner of the U.S. Nationals ?
Beard, the finish line isn't crooked or anything like that. I've seen this happen over and over in super stock and people get screwed.... that is; the wheel of one car (Richardson/ Barone) trips the finish line beam and the nose or the "fin" (in this case) of the other car (Coans) does trip the finish line beam. Is Richardson's wheel in front of Coan's wheel?- Definitely! Is Richardsons "fin" in front of Coans "fin"? Yes! But Richardsons fin didn't trip the beam and Coans did. Could be the angle of the fin, his track placement etc etc. End of Story. It Happens all the time in Super Stock with the noses of the late model cars but now that it happened on the big stage in comp, it's coming to a forefront. Have you ever seen a guy in class run a crazy high mph and wins by a few thousandths? Same concept. It should have been done long ago.
NHRA/ Imbrogno/ Foster or whomever needs to lower the finish line beams to 1 to 2 inches (In the sportsman categories) so that the front wheels of everyones car trips the beams and this will fix the problem of a late model car tripping the beams with his nose and the other older car tripping the wheel with the wheels. Or in this case a fin of one car tripping the beam and the other cars fin not tripping the beam. In the PRO categories they can leave the beams the way they are so that the cars don't jump over the low "sportsman" beam. They could have this programmed in the computer.
Inquiring Mind is offline   Reply With Quote
Old 09-10-2007, 06:27 PM   #2
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
Here's a shot somebody posted on DRR...
Not even looking at Scotty's 'fin', the sloped nose of the car has to trip the beam. Above and beyond that, even Coan's nose isn't 13" in front of Scotty's front tire, even if there wasn't body work in front of it!
Old 09-10-2007, 06:49 PM   #3
Keith Mayers
Keith Mayers's Avatar
this opens a can of worms. steve johnson all over again? what will be the answer, mike, you sure look right to me.
Keith Mayers
2005 H/R W/C
www.mayersmotorsports.com
Keith Mayers is offline   Reply With Quote
Old 09-10-2007, 07:54 PM   #4
Inquiring Mind
I know what you are saying Beard. Scotty's nose/ front end should have tripped the beam but that's my point. It doesn't always work that way, that's why you see mph fluctuation sometimes of 3 to 5mph (sometimes the front ends take it and sometimes they do not). It happens all the time, thats why they need to lower the beams. It would make it a tire to tire race and take all the guesswork out. No more wondering.
Bottom line, Scotty and Barone got screwed (but so have alot of other people in the same situation) This is a totally different deal than the Pro Stock Bike.
Old 09-10-2007, 10:24 PM   #5
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
I lost a race this past weekend where I was on the brakes and ran over 1.5 mph faster than my best run over 3 days. No doubt in my mind the lights were tripped by my nose on that run and it looks clear that Scotty should have "dumped" to get the win at Indy. I had not seen those pictures before.......Racers obvioulsy have to know their own cars and what and where they trip the lights with.......I thought about it on my car but never addressed the problem and now it bit me..........
Rich Biebel
S/C 1479
Stock 147R
Old 09-11-2007, 05:36 PM   #6
Larry Sullivan
Liked 3 Times in 1 Post
Default Re: Richardson Barone, winner of the U.S. Nationals ? (Redirected. May affect every
Video frames are misleading - the top of the frame was scanned 1/60th of a second before the bottom of the screen frame (30 frames per second, two interlaced scans per frame), so the car in the nearer lane always appears to be ahead of its actual position because it was scanned later. In other words, you need a snapshot, not a vertically scanned video image, in order to get a true picture, or you need a video system that scans a lot quicker than 30 frames per second. The MOV in this example (.0047) is much smaller than the video frame uncertainty (.0167). And, given the angle of the finish stripe in the frame, the camera was not perpendicular to the track, further distorting the image.
Larry Sullivan is offline   Reply With Quote
Old 09-11-2007, 08:45 PM   #7
mannymen
Liked 13 Times in 7 Posts
Did anyone out there Tivo the finals?
N/A
mannymen is offline   Reply With Quote
