Old 10-03-2013, 06:41 PM   #1
D.Johns
D.Johns's Avatar
Liked 18 Times in 6 Posts
Default Re: Supercharged COPO Engine!!!
Originally Posted by FED 387 View Post
OK so if this Chevy engine makes 1110 HP and 850 TQ that comes out to about 3.39 HP per cube and 2.59 LB TQ per cube--- what is normal for a supercharged engine---the best NA Comp eliminator engines are only making about 2.7 HP per CI and Pro Stocks are making about 1300 HP or 2.6 HP per CI??? Or if we took off the supercharger what would the HP be for that engine???
Pro-stock is around 3hp per CI right now. Doing the quick dirty math with this particular engine is probably around 490-510 NA. It takes roughly 150hp to spin the Supercharger in this application. However without getting into a bunch of variables that's more of a S.W.A.G.(Scientific Wild ***** Guess)
There are a LOT of variables in a supercharged application to have a "normal" or "standard". Type off supercharger(roots, screw, centrifugal) size of supercharger and it's efficiency range, Engine and it's volumetric efficiency. Amount of boost(the measurement of back pressure in the system).
The better an engine is in NA form the better it will be in Supercharged form provided the type of fuel being used can support it.
2014 Cobra Jet FS/XX #3345 STK/SS
Like us on http://www.facebook.com/pages/Daniel...25886327426822
D.Johns is offline   Reply With Quote
Old 10-03-2013, 07:21 PM   #2
Rat Raceway
Rat Raceway's Avatar
Liked 35 Times in 17 Posts
Send a message via MSN to Rat Raceway
The Email ATI sent out...
The ATI COPO Camaro #008 Sets the NHRA SSA/A Record at Englishtown
[ame="http://www.youtube.com/watch?v=6JcFs9ukel8&feature"]COPO #008 at Englishtown LODRS - YouTube[/ame]
New NHRA SSA/A Record: 8.449 @ 161.83 MPH
The ATI COPO is running strong! This weekend was the first time running the car in air under 75 degrees and the performance really took off! "Actually, it took off a little more than expected", Beattie, Jr said. "We were able to set the Super Stock SSA/A record at 8.449 and 161.83 MPH." The ATI crew took the motor apart for tech inspection, easily passed, and put it back together in order to make first round. The ET and MPH records where set at 3600 lbs, on a true 10.5" Hoosier, and running VP C16. The performance of the ATI COPO speaks volumes for the package the guys at GM put together for all the COPO owners to race.
Naturally, ATI’s COPO Camaro is fitted with plenty of ATI's performance products, including ATI’s Fuel Comp T400 transmission in an ATI SuperCase, paired with a 9" Fuel and Blown Torque Converter. The trans is filled with Super F ATF and mated to an LS1 crank adapter and flexplate with a 10 Rib ATI Super Damper to run the supercharger. The Katech built motor is from all factory parts and to factory specs as GM supplied and the Whipple 4.0L blower has never missed a beat. The ATI crew is looking forward to going some rounds in the upcoming races before the season is over.
Ross Gregory
5133 Stock,Super Stock
53 Top Dragster
Rat Raceway is offline   Reply With Quote
