#1 | |
Liked 3,178 Times in 972 Posts
Great that they responded...hopefully they gave Mark Lelchook some formal feedback on the alternative solution he discussed with them at Indy this year. I don't think this whole deal has anything to do subterfuge or under the table dealings, just an Engineering group working with a liability-adverse bunch of bureaucrats and the corresponding absence of common sense approaches. This will hopefully result in a reasonable cost solution. On my chassis car (yea, I know our classes are a different animal) I initially balked at diapers but when I dealt with Diaperman and put his on I quickly recognized I was getting a good value that increased safety.
Liked 46 Times in 29 Posts
Is there a possibility the NHRA's insurance company is requesting these after someone hearing of an accident or injury happening somewhere at some track?
I sure do understand if you can weld a roll bar, this would be a piece of cake to make. you guys have shown some nice designs on this thread. |
Liked 52 Times in 17 Posts
OK, it seems it ain't going away, (can't believe it made it this far, SHRA?) but I have got to get an answer with this question ---- ' if you have an approved tether system and somehow, somewhere, blackhole, planets aligned wrong or whatever and ya **** breaks free and does some damage i.e still hits somebody or something, WILL NHRA take responsibility cause they approved it??
how does that work when **** goes wrong in the oiler classes ? they must have more 'approved parts' then us ??? inquiring minds need to know!
Bernie Cunningham 7053 STK |
#4 | |
" The NHRA Technical Department will also accept a minimum ½” (half inch) stich weld located each primary tube as an alternative to the tethering system." Don't insult our intelligence with this BS response! Weld my headers onto the car? Only a moron with no knowledge of race cars would suggest this! .
Jim Wahl....NHRA #2239 S/SS - IHRA # 8 Stock, D2 Stock Champion (forever I guess) 2019 Baby Gators Stock Champion 2009 NHRA D2 National Open Stock Champion 1982 NHRA D2 West Palm Beach LDRS SS Runner Up Past President, Southern Stock / Super Stock Association. ![]() Last edited by Jim Wahl; 09-18-2013 at 12:23 AM. |
#5 | |
Jeff Lee 7494 D/S '70 AMX |
#6 | |
They should also change the "bolt" ruling to say that each tube that goes into a collector have its own bolt and brackets, this would allow for differences with 421 type headers verses 4into1 headers. I understand the ruling is 4 bolts per collector, referring to a normal 4into1 collector? I am not aware of any foolproof way of keeping headers intact besides a regular maintenance inspection of hardware as it is subject to intense vibration and will fail given enough time. NHRA guys are not going to get under every car and make sure that even their "bolted" retaining devices are still intact. The whole thing is obviously a attempt to limit exposure to lawsuits and throw them off onto manufacturers instead of those organizations who don't or can't inspect cars they let run on their track or work to protect their "customers" from being hurt at their events. |
Liked 316 Times in 67 Posts
My Nomad has fender well headers, very obvious to tech, I'm curious how tech will go checking low-to-the-ground Colbalts, etc with headers tucked well under the frame.....our SS/MA '57 needs a trans blanket and never once has tech knelt down and looked.....I suppose some might be visible from engine compartment
#8 | |
Liked 136 Times in 49 Posts
#9 | |
Ed Wright 4156 SS/JA |
Ed,
Many race cars require disassembly of the headers to get them on & off the car. Heck, you can't even change the starter on my car without taking the collector off and loosening the flange bolts up @ the head. Stitch weld them up and they are on the car until you take a sawzall to the headers!
