#1 | |
Liked 904 Times in 237 Posts
This in My mind is one safe way to avoid some crazy situation where if you do your own and it falls off who is more liable you who build your own or the NHRA approved Tether builder approved by NHRA ?
Don Kennedy 7701 SS |
Liked 11 Times in 8 Posts
Again...instead of forcing everone to buy a product that a small minority THINKS solves a problem that 90% of the racers do not see as an issue. Why not instead spend the effort toward keeping people out of harms way? If you were to walk across a busy freeway without being conciuos of your surroundings and get hit...who's liable? Standing behind a car doing a burnout and expecting NOT to be hit by something, be it a rock, nut, bolt or collector is irresponsible.Didn't an entire funny car body get launched into the crowd at the Charlotte race? Anyone hurt? What's NHRA going to do with that? Face it racing is dangerous even as a spectator, nascar, NHRA, local tracks people have and will continue to get hurt both as particpants and those merely watching. Knee jerk reactions have never solved anything,only a way of saying they've addressed the "issue". Now that said if this winter the rule still stands I'll be looking for options to abide by the ruling.
Joe Buchanan SS/BX 3117 |
Liked 335 Times in 182 Posts
I am all for safety !!!! However when it comes to mandates and a solution that is equivalent in all aspects that can be fabricated by a racer for a "nominal" cost versus a NHRA approved manufacturers system for "hundreds" of dollars more I think bears looking into. Their has to be a happy ground here. Look at the engine diapers mandate. If you can fabricate a diaper that meets NHRA guidelines you do not need to purchase a "store bought" diaper--- this should be the same way too--- MY OPINION!!!!! FED 387
#4 | |
Liked 905 Times in 193 Posts
Bob Don 128 SS |
#5 | |
1. NHRA would be sued for lack of enforcement or approving a device that was not designed properly that did not provide 100% safety. 2. The manufacturer would be sued for workmanship, manufacturing defects and/or improper assembly instructions. 3. Since the racer/owner needs to assemble the tethering device, he would be sued for not assembling or installing the device correctly, and then the racer would blame the manufacturer and NHRA. This is the world I live in as part of my job; it is called Product Liability and Torts. I know of a case in which a private pilot, purchased a commercial/automotive GPS to use on his private airplane when he went hunting. He lost his life when he crashed his airplane during bad weather and while using the GPS. Although the manual for the GPS warned and stated that was not approved for aviation use, due to the fact the manual showed pictures of different types of vehicles such as cars, trucks, boats and an airplane, the manufacturer lost the lawsuit. The court established through its decision that although there was language and warnings that the particular GPS was not approved or designed for airborne/aviation applications or use, just having the picture on the cover of the manual, inferred that it was for use on airplanes. |
#6 | |
