Old 09-15-2013, 07:12 AM   #1
David Lee
Liked 346 Times in 126 Posts
Default Re: NHRA Tether Rule Update
just another way fo for the NHRA to extort money from manufacturers and racers,
Old 09-15-2013, 08:20 AM   #2
Crew Chief
Liked 10 Times in 6 Posts
I hear this mandate came down from NHRA's legal department after an incident where someone was hit by a collector that came off in the water box. If that's the case, they would want legitimate companies making the tethers because liability would then fall back on the manufacturer in a lawsuit.
Crew Chief is offline   Reply With Quote
Old 09-15-2013, 10:17 AM   #3
SSGT Mustang
Liked 204 Times in 54 Posts
I heard that too. But don't know how they can try to sell that explanation with a straight face when they promote fuel cars that explode and send shrapnel everywhere, including whole funny car bodies, at least a few times every year. You see cars losing their hood or hood scoop, nitrous backfires, lost blower belts, broken rear ends. The list goes on and on. I've seen each of those examples more than once, but never a lost collector.
I like going into the fuel pits to see and hear the cars fire up before their run, but always stand about 20 feet back because I'm just waiting for one of those things to blow up with everyone around it. I can't believe that it hasn't happened yet.
Nevertheless, the collector rule, no matter how they try to spin it, just seems like a poorly thought out "solution" to an almost non-existent problem. It's a sign of an incompetent bureaucracy at its best or worst, I can't decide.
Hell, if they expect tech to look under every car for approved tethers, then surely they can require them to look underneath cars for a properly fabricated tether made by the average racer. It's not brain surgery to make a pair of these things.
SSGT Mustang is offline   Reply With Quote
Old 09-15-2013, 11:03 AM   #4
astikhossw
astikhossw's Avatar
Liked 20 Times in 9 Posts
Aristophanes ????
astikhossw is offline   Reply With Quote
Old 09-15-2013, 02:43 PM   #5
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
In this incident how was the collector secured?, did it have mounting tabs, were the bolts and lock nuts there?.Were they stainless with the spring mounting deal?. I cannot see how the collector can come off, if you have 2 tabs welded on 2 pri. pipes and 2 on the collector secured with 1/4 bolts and steel lock nuts.Unless the pri. pipes or collector are so badly rusted and blow through.In that case the pri. pipe can blow before the pri. clamp on the tether rendering it useless.This deal is an insult to a racers intelligence by NHRA!.
Old 09-15-2013, 04:26 PM   #6
Jody Lang
Liked 92 Times in 29 Posts
Rust, loose bolts, no bolts it doesn't much matter. Fact is that exhaust pieces have fallen off during burnouts and down track.
In one case it was during the burnout and the piece came back and broke a leg.
One question I have is... Why SFI on collector tether, but no SFI requirement for ladder bar tether???
We should be able to piece together our own system.
Jody Lang is offline   Reply With Quote
Old 09-15-2013, 04:43 PM   #7
Richard Grant
Richard Grant's Avatar
Liked 13 Times in 7 Posts
This problem seems to have a much simpler solution than spending $200 for a special NHRA approved tether when a proper inspection of the use of tabs and lock nuts would accomplish the same result.
Richard Grant 4988 STK
Richard Grant is offline   Reply With Quote
Old 09-15-2013, 04:55 PM   #8
Charlene Gullett
Charlene Gullett's Avatar
Liked 7 Times in 2 Posts
Isn't that why we sign that 1000 word waiver? Anything can come flying at you if you are standing on the starting line.
A couple of years ago I had a connecting rod cap shoot out from under a stocker and whack my in the leg-no broken bones, just a nasty bruise. This spring in Vegas an open rear wheel roadster came out of the burnout box ( I was in front of this car) and a rock shot overtop of the rear wheel towards the starting line and hit me square in the center of the forehead. That was an attention getter. You cannot tether everything on these cars. I believe if you are standing on the starting line you better pay attention-this is a high risk area. if you stand there with the deer in the headlights look, you may get injured.
6521 GT/MA 85 Cutlass
Charlene Gullett is offline   Reply With Quote
Old 09-15-2013, 05:55 PM   #9
Rob Petrie E395
Liked 216 Times in 77 Posts
Quote of the night from last night at the track. Right after a car threw something out during what looked to be a engine failure. Guy was standing next to me and with a straight face turns and says. "Oh F_ _ _! now they are going to want connecting rod and engine block tethers on too" LOL
Old 09-15-2013, 06:02 PM   #10
SSDiv6
Just to clarify, it is not a SFI requirement or specification.
It is a NHRA rule change and the product must be approved by them.
Yes, there are various lawsuits against NHRA due to collector injuries.
Although racers and crew members sign a release, they can still hire an attorney and sue NHRA trying to seek compensation.
