Old 09-13-2013, 12:39 PM   #1
FED 387
Liked 330 Times in 178 Posts
Default 80 Camaro hinges needed
need both L/R hood hinges with springs and the 4 bumper bolts for the hood --these bolts are the ones with the rubber cushions 2 are on the cowl are and the other 2 go on the core support area---nothing fancy plain old stock is preferred--DO NOT WANT TO SPEND A FORTUNE HERE !!!!!!!!!! - PM me with what you have Thanx FED 387
Old 09-13-2013, 02:07 PM   #2
Joe Toller
Liked 4 Times in 4 Posts
Default Re: 80 Camaro hinges needed
I can wrangle up a set here in Montana pretty cheap. Let me know what you were thinking to spend and I can get you taken care of.
Old 09-13-2013, 02:11 PM   #3
FED 387
thinking along the line of say like $10-20 for all-- get back to me please---FED 387
Old 09-13-2013, 02:14 PM   #4
Joe Toller
I will check after work around 4pm, but that should be doable.
