Old 09-04-2013, 11:26 AM   #1
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Re: Project Junkyard Dog
Originally Posted by Dave Noll View Post
Where do you find someone that will grind a crank that way ? .... All I get around here is "Hrmph..Stock specs is good enough. .013 won't get you nothin. You know how much things are flyin around inside there?"
Good point..
Boom for the Buck you are correct, get only 1 or 2 more cu in.
However it will provide extra compression.
An improvement differential of .026 in
Like putting on a thinner gasket.
Dan
Old 09-04-2013, 11:54 AM   #2
Joe Toller
Liked 4 Times in 4 Posts
True, and odds are as I put more boost to it, I will hurt it. There's not alot of meat in a Buick V6 crank to begin with. Looking back I probably could have done without it, but I also expect, as this is a learning experience, that this motor may not last anyway. That's why I have enough parts to build 2 more lol...
Old 09-25-2013, 06:23 PM   #3
Joe Toller
I have decided it will be best to make this car a 78, better HP break that way. I scored a correct 78 intake and new turbo (to keep as a spare) off Craigslist for $300. The heads are at the machine shop now. It will make a neat comparo, as the car is currently set up as a 79. As long as the weatherman is wrong and it doesn't snow tonight (yep), I should have numbers this weekend!
