Old 09-01-2013, 07:48 PM   #1
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
Smile Re: Heard in the Stands at the Indy
Carey, I was just thinking, just use those tethers that Johnny Gray used a month ago out west, they sure did the job.
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
Old 09-01-2013, 07:57 PM   #2
Ed Wright
Ed Wright's Avatar
Default Re: Heard in the Stands at the Indy
Cary, I'm still trying to figure out how the tech guy saw how big a hole you had behind your flywheel. Did you go to tech with the transmission and floor pan removed?
Ed Wright 4156 SS/JA
Old 09-01-2013, 08:08 PM   #3
joe176
joe176's Avatar
Liked 41 Times in 9 Posts
Been watching the Yellow Bullet Nats live online from Cecil County .... These guys are having fun ... Imagine that ... And they get live Internet coverage ...
Joe Franco SS176
joe176 is offline   Reply With Quote
Old 09-01-2013, 08:40 PM   #4
Bench Racer
Liked 99 Times in 21 Posts
I think NHRA has bigger issues to worry about than an inch of clearance on a crankshaft by the scatter shield, With the RPM that Honda will buzz I don't think anything that explodes in the can will be heading inward, at least not according to the law of physics. NHRA made a class for the car, don't punish him for showing up. Don Jackson
Bench Racer is offline   Reply With Quote
Old 09-01-2013, 11:48 PM   #5
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
X2. Someone had to of said something for them to look.
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 09-02-2013, 01:03 PM   #6
boostedf22c
boostedf22c's Avatar
I guess if you have a 10,000hp Funny car you don't have to abide by this rule.
Carey Bales
316D DD/AT
www.racetactics.net
boostedf22c is offline   Reply With Quote
Old 09-02-2013, 01:04 PM   #7
Mack Reeves
Mack Reeves's Avatar
Liked 44 Times in 13 Posts
That about says it all.......
Mack Reeves
2377 STOCK & SUPER STOCK
Old 09-02-2013, 03:37 PM   #8
rognelson777
Liked 135 Times in 74 Posts
Carey, Nhra may be cracking down on transmission certified products. I believe there maybe a mandate out there right now to look hard at transmissions and certs. At the atco divisional recently a Super street racer failed tech for transmission sheild cert. Think about how hard it is to check the cert on a super street car, most are full body cars, and it would be very hard to check, but they did and car failed tech. There was also a instance of another 4 cylinder car in comp that had a adapter fail. So maybe they have decided to check real hard, hope they were not picking on you. and remember there are many things that sometimes do not make sense but you have to decide if you want to live by their rules or not.
rognelson777 is offline   Reply With Quote
Old 09-03-2013, 09:29 AM   #9
boostedf22c
That's whats crazy though. I did everything they asked me to do. I went and got my can converted from 6.1 to 6.3 and updated the cert. Same with the clutch and flywheel. This all started on Tues and ended on Friday. I never once filled out and handed them a tech card. I never told them I was ready to be tech'd in, nor did they tell me that they were teching me in. It's all really fishy to me.
I'm all about safety, and had EVERY safety item needed to run the ET/MPH that my car runs. I had no problem doing everything they told me I had to do in that 3 day span (and the tech guy literally told me these were the 3 things I needed to do so I could race). I have no problem following rules either, but as posted above, everyone should be held to the same standard if they are going to enforce such a rule, and clearly they aren't.
Also, rules need to evolve a bit. I'm going to be speaking with someone about this, because I feel this particular rule needs to be revised.
Any suggestions from some of you guys that have been through this? Who would be the best person to talk too, etc.??
Thanks for all the support, it's actually quite overwhelming. All the messages, facebook posts and messages, visits by the pits, it's all much appreciated.
Carey Bales
316D DD/AT
www.racetactics.net
