#11 |
Liked 13 Times in 9 Posts
>> I am not sure even why we are worried about every one else, because you should run your car, according to the rules set forth, and not worry about every one else.
Wow... That would be true if the rules set forth were being administrated equally and properly. If there is a concern that such is not the case, then I think people have a right to be concerned! Take Patrick out of the equation -- from what I've read, I agree with you. There were others in the barn that were in question. Are you saying that folks shouldn't worry about someone being passed who was in fact illegal? To me, the worst Indy teardown story is still regarding a gentleman who was tossed for actually having STOCK heads. (Figure that one out.)
#12 |
ONE person did not decided Doug Patrick's fate at Indy. There were multiple tech officials that looked at and check the head. We are not talking about improper weight of pistons, a ring flange being to high, or any of the other problems... we are talking about a descrepency in measurements of over 2CC's. If there had been a consistant wrong measurement then the fault would lay soley on Doug and Bob Dennis, however when you can not duplicate a measurement of liquid, how can you say that person is wrong... the fault at that point lies with NHRA tech officials.
If they would have been able to duplicate numbers just once then this would not be such a big deal. However, please do not judge the entire situation and classify someone in the same category as those that come in with pistons to light, or ring flanges that are not right, especially when it is not their fault that the tech officals can not get a proper reading. I am not one for people that cheat either, and I would not defend someone who I knew to be 100% wrong. However, I will defend someone who is getting crucfied for nothing. Jeremy Waibel B/SA 2231 |
#13 |
Liked 66 Times in 37 Posts
Jeremy take some advice and stop posting on issues you have no idea what your talking about. Doug did great in the eliminator and I'm very happy for him. Leave it be...
#14 |
Liked 459 Times in 113 Posts
jeremy,
i agree about a 1/2 cc is only slightly wrong... and charley bob got what he had coming for the pistons... but the POINT here is... wrong is wrong... at least it used to be anyway... i think you all get my opinion, like it or not. jack mccarthy
Jack McCarthy 3609 STK "the Captain" |
#15 |
If you look at them I was the one that started the post of Doug being 100 % legal !!! I am very proud of him as well I think that he showed a great representation of Division 2.
#16 |
Liked 244 Times in 26 Posts
The "liberal enforcement" of the rulebook is one of the main reasons I stopped racing a few years ago, and will be the main reason why I will not race much after this point.
Let's start a list of items NHRA tech has scewed up on: 1. Doug Partrick allowed to race after having too small by 0.5 cc combustion chamber. 2. 4-angle valvejobs in stock, can't remember who. 3. A 440 cid engine with 400 main journals, Steve Wann. 4. Aluminum heads on originally cast iron, Bill Hawk. 5. Single 4bbl head on originally dual four bbl, 67 Shelby 6. Closed chamber heads replaced with open chamber heads (or vice versa), 396 BB Chevy Rectange ports. 7. Year model 1998 Lt-1 engine, they were actually LS-1's. |
#17 | |
Liked 1,575 Times in 580 Posts
1. NHRA Rule book, Section 19.6.2, Page 264, Paragrah 2: Margin of error is 1% of 1cc. There is not a burrettte that is that accurate, not even electronic. 2. 4 angle valve jobs are illegal according to the rule book. 3. There is no rule in Super Stock that prevents the use of the 383 block as a 440 block. What if you bore the mains to a 400 size? If you look, the rules apply to the conecting rods journal size and not crankshaft. 4. Aluminum replacement aftermarket heads have been approved for many, including Ford and Chevy. 5. Dual 4bbl.; blame NHRA and not the racer. They did what NHRA allows anyone to do; show documentation. The same pratcice has been used to incorporated other engines in the class such as the Olds 350 EFI that was used in the Cadillac. 6. Closed chamber vs. Open, blame again NHRA and not the racers. 7. LT-1 engine use; NHRA allowed it. In a nutshell, NHRA makes the rules and the call, not the racer. |
#18 |
SS Div6,
Please read all the words. Chris |
#19 |
Liked 3 Times in 1 Post
Chris i have explained time and time again why the LT1's were made legal for the 98 Camaros and Firebirds,,,,,,,,let it rest son, your bitching isn't going to make it go away! Bitching about NHRA and the Tech issues isn't going to help either, believe me, i have been there and done that. The Tech guys are trying their damnest to do their Job!
Woodro Josey 2002 STK |
#20 |
[QUOTE=FlyingW;39731
I know when I go to National events and even divisional races, VERY few times have I had time to go down to the tech barn to be nosey and see what was going on ? Jeremy Waibel B/SA 2231[/QUOTE] At the Indy U S Nationals, on tear down day unless your running a SSer also, you have nothing to do.
Bud Lefevre 3075 STK IHRA World Record Holder |
