Liked 232 Times in 39 Posts
What is the tolerance on valve diameter from the NHRA apecification?
Marty Buth 3657 STK |
Liked 26 Times in 13 Posts
2007 Rule Book Pg 55. "Valve diameter tolerance +0.005" or -0.015" from NHRA specs."
Liked 780 Times in 194 Posts
From the rule book under section Engine:1, Cylinder Heads, "Valve-diameter tolerance: +.005" or -.015" from NHRA Specs." You do have a rule book, don't you?
Thanks for the response. That was my memory, but didn't have the rule book handy.
Liked 1,938 Times in 583 Posts
Marty,
Make sure that you check the NHRA specs. They dont always match the OEM valve size. I got tossed for an intake valve that was - 0.016. By Westley of course. Mike
Mike Pearson 2485 SS |
Mike,
Thanks for the heads up. My brother and I both run 2300 ford motors and they are different, even though you can buy a lot of valves that are after market for both years of our cars. Thanks, Marty
