Old 08-09-2013, 11:01 AM   #1
Jim Kaekel
Liked 535 Times in 110 Posts
Default Re: Predicting 1st qualifier ?
Originally Posted by Mark Markow View Post
The temp of the fluids? I always pick up a couple on the second run
X2 You may not be warming the engine and driveline up enough prior to your first run.
Jim Kaekel 3836 STK
Old 08-09-2013, 04:53 PM   #2
Stock726
Liked 13 Times in 9 Posts
Even warming it up on jackstands doesn't seem to work as well as making the first pass, from my experience anyway.
I think there maybe more factors involved besides oil and water temperature??
Stock726 is offline   Reply With Quote
Old 08-09-2013, 06:50 PM   #3
michael mercer
Liked 2 Times in 2 Posts
Put a temp gauge on the trans. Trans fluid temp will definately make a differance.
Get up on the converter in the staging lanes or get a magnetic pan heater.
michael mercer is offline   Reply With Quote
Old 08-09-2013, 10:07 PM   #4
SmBlkFord
So you guys think temp is doing it ? I warm it up good through the pits but never got on the transbrake. Try to keep the water temp around 160-180 when I go in. I can`t get it any closer then within 20 deg. if that would make that much of a difference ? Thanks
SmBlkFord is offline   Reply With Quote
Old 08-10-2013, 10:16 AM   #5
Ed Wright
Ed Wright's Avatar
You see cars driving down the return road to the end and back each morning at the races for a reason. I would not warm mine up on jack stands myself. I (and several others I encounter doing the same thing when I am) drive down the return road to the end, turn around, stop, set on the trans brake for ten seconds, and if the scales are open check my weight. The digital scales we have now don't vary much, but you never know. When I get back I plug in my cool down battery & charger until I get the engine back to ambient. Always runs the number first pass.
Ed Wright 4156 SS/JA
Old 08-10-2013, 11:40 AM   #6
countrypuppy4865
countrypuppy4865's Avatar
Liked 228 Times in 70 Posts
Could possibly be spark plugs loaded up and maybe after making one pass it cleans them up?
Jimmy "Cooter" Hidalgo, Jr.
4865 E/SA '04 GTO
4865 SS/GA '99 Firebird
Old 08-10-2013, 02:46 PM   #7
Ed Wright
Ed Wright's Avatar
I would think you would hear it miss. If tuned correctly, your plugs will always stay clean.
