Old 08-01-2013, 11:25 PM   #1
KURT GROSS
Default Which SBC Stainless Roller Rocker?
I am at the point i need to purchase rocker arms and feel i have narrowed it down to three brands and could sure use everyone's opinions. I have a 1971-72 Nova 350/270 with 7/16 studs. The three choices i seem to be leaning towards are:
PRW Pro series Stainless $299.50
COMP Cams Hi-tech Stainless $384.00
Crower Enduro Stainless $526.00
Not familiar with PRW and Crower is sure at the top of the $$ range so my gut tells me COMP.
Also would like to know everyone's pushrod choices (brand and wall thickness) as i would imagine i will need to purchase new also for correct length/geometry.
One final stupid question. I assume i have to run guide plates?
Sorry for all the questions but i am new to Stock and would really like some veteran guidance here.
Thanks!
Kurt
2001 Division 6 S/ST Champion
2002 Jegs Allstar
2010 Woodburn Dragstrip S/P Track Champion
KURT GROSS is offline   Reply With Quote
Old 08-01-2013, 11:56 PM   #2
Geerhead55
Liked 5 Times in 5 Posts
Wink Re: Which SBC Stainless Roller Rocker?
Kurt,,, I've had good luck with the Comp stainless rockers,,, a good investment, I think.
I haven't seen the PRW rockers,, but I've tried one of their stud girdles and I wasn't
too impressed with it. My 2 cents,,, good luck which ever way you go.
Danny Durham
Old 08-02-2013, 07:33 AM   #3
Liked 1,880 Times in 422 Posts
Default Re: Which SBC Stainless Roller Rocker?
Comp Cams. Call Tim Cole, you need the new special rocker for Stock Eliminator. Tim will also hook you up with 3/8" guide plates and the correct pushrods. You cannot go wrong with the new stuff Tim and Comp have developed for Stock Eliminator. It was developed with direct involvement with some of the best engine builders in the country. Tim Cole at Comp is the "go to guy" for a lot of us.
Old 08-02-2013, 07:52 AM   #4
Ed Wright
Ed Wright's Avatar
I used the Comps for years. Very reliable.
Ed Wright 4156 SS/JA
Old 08-02-2013, 08:09 AM   #5
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
Comp stainless is good rocker.
Mike Taylor 3601
Old 08-02-2013, 11:44 AM   #6
REGGIE WINKLES
Liked 39 Times in 9 Posts
Comp has the "new" 1/2 stud rocker system for the SBC which should work just fine on the stocker engines.
Reggie Winkles 2650/Stock
REGGIE WINKLES is offline   Reply With Quote
Old 08-02-2013, 01:16 PM   #7
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Dave Noll, EF/S ,?/SA 6526
Old 08-02-2013, 11:30 PM   #8
KURT GROSS
A big thanks for everyone's advice. Very much appreciated.
Alan and Reggie - My Stealy heads already have 7/16 studs. Is 1/2 really needed?
Kurt
2002 Jegs Allstar
Old 08-03-2013, 08:15 AM   #9
SS 230
check pm
SS 230 is offline   Reply With Quote
Old 08-03-2013, 09:28 AM   #10
Kurt
The studs are 7/16" on the bottom and 1/2" on the top, no machine work necessary.
You cannot make valvetrain too stiff. The stiffer it is, the more reliable it is and the better it works. Call Tim and talk to him.
