Old 08-02-2013, 07:33 AM   #1
Liked 1,826 Times in 414 Posts
Default Re: Which SBC Stainless Roller Rocker?
Comp Cams. Call Tim Cole, you need the new special rocker for Stock Eliminator. Tim will also hook you up with 3/8" guide plates and the correct pushrods. You cannot go wrong with the new stuff Tim and Comp have developed for Stock Eliminator. It was developed with direct involvement with some of the best engine builders in the country. Tim Cole at Comp is the "go to guy" for a lot of us.
Old 08-02-2013, 07:52 AM   #2
Ed Wright
Ed Wright's Avatar
I used the Comps for years. Very reliable.
Ed Wright 4156 SS/JA
Old 08-02-2013, 08:09 AM   #3
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 306 Times in 103 Posts
Comp stainless is good rocker.
Mike Taylor 3601
Old 08-02-2013, 11:44 AM   #4
REGGIE WINKLES
Liked 39 Times in 9 Posts
Comp has the "new" 1/2 stud rocker system for the SBC which should work just fine on the stocker engines.
Reggie Winkles 2650/Stock
REGGIE WINKLES is offline   Reply With Quote
Old 08-02-2013, 01:16 PM   #5
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Dave Noll, EF/S ,?/SA 6526
Old 08-02-2013, 11:30 PM   #6
KURT GROSS
A big thanks for everyone's advice. Very much appreciated.
Alan and Reggie - My Stealy heads already have 7/16 studs. Is 1/2 really needed?
Kurt
2001 Division 6 S/ST Champion
2002 Jegs Allstar
2010 Woodburn Dragstrip S/P Track Champion
KURT GROSS is offline   Reply With Quote
Old 08-03-2013, 09:28 AM   #7
Kurt
The studs are 7/16" on the bottom and 1/2" on the top, no machine work necessary.
You cannot make valvetrain too stiff. The stiffer it is, the more reliable it is and the better it works. Call Tim and talk to him.
