(1) set of heads up 041 heads , Manley triples, titanium retainers welded ex. The heads are off of a 1970 LT1 they have 2.02 in. One head leaks $1500 for the set
One set of Koni double adj, rear shocks 19.5 centers 150.00 1-set of Crower Maximus lifters, 20 runs .840 550.00 (1) 3-quart accusump 100.00 6- sets of miller pistons 2-ring, 4.060 to 4.070 bore, make offer 1-set of Manley rds. ..875 pin, 350 main 300.00 1-Stinnet 780 Holley like new 500.00 1-Mallory 250 fuel pump with reg. 125.00 1- Rossler lightweight powerglide. ATI super set 194, roller tail , aluminum hub, drum 1800 |
Are the heads still available and is the leak in the int. port, exh. port or the chamber?
Thanks. |
Liked 31 Times in 7 Posts
Do you still have the Stinnett 780 Holley?
hi there are pistons still available ?
Liked 8 Times in 7 Posts
Hi,
You have a PM. Thanks, Dan |
Hi Fred,
When you read this either send me a private message, or call me at 937-770-1357. I've tried to send you 2 private messages about the Koni shocks, and I don't know if they are not going through or what? Please contact me even if they are sold, so I know you got the message. Thanks , Dan |
