Old 07-11-2013, 07:23 AM   #11
Robbie Welch
Liked 262 Times in 124 Posts
Default Re: Header coating
Kris, I'll take some photos when I take them off after the PRO AM for coating,and report on any performance changes.
Old 07-17-2013, 07:44 AM   #12
Robbie Welch
Well I ran the car with the new headers on it this weekend. As you may know I'm a .90 guy and the results where inconclusive. I ran it off the off on the first run but it wasn't a good clean run and went 10.32 128mph. That seemed a little slow but the mph seemed pretty good for the weather. On the stop it seemed to take quit a bet more to slow the car to 10.90 and it still went 128. I felt like with the weather correction numbers for the weekend it would of run 126 or so in the past? We'll see. I know this isn't the .90 form but you guys seem to respond more . Thanks Robbie. Now to put the disc brakes on. Anyone want to guest what the car will go after that? I'm going from 4 wheel drum to 4 wheel disc.
Old 07-17-2013, 08:33 AM   #13
jmcarter
jmcarter's Avatar
How much weight will you lose in the brake change? If ~100 lbs and you then re-add the weight in ballast it becomes unspung mounted low and more to the rear which means the car will react quicker but probably not much quicker. If you lose that weight then I'd say .07-.08 quicker. Cars on a stop have more variables involved than a regular class car but I'd be interested in what you come up with.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 07-17-2013, 08:38 AM   #14
jmcarter
jmcarter's Avatar
BTW, if you didn't put on merge collectors contact Mark Lelchook for a set of his, you will not be disappointed.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 07-18-2013, 06:35 AM   #15
Robbie Welch
I do'nt think it will be a100lbs but it could be 40 or 50 lbs with half of that being rotating weight (the rear brakes) I have weight at the rear bumper so thats where I'll add this (2800 min). We have a standard collector on it now, a merge collector is in the plans.I'm also going to raise the front of the car about 1 1/2 " this should make it almost level. I'm hoping the front brakes and raising the front of the car will help the car come out of the lights quicker. Now I have to get the header headers off and to the coater. Robbie
Old 07-22-2013, 09:47 AM   #16
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
My headers were several years old, and all rusted up. NitroPlate did an awesome job with them!
BEFORE:
AFTER:
Old 07-23-2013, 10:14 AM   #17
ALMACK
ALMACK's Avatar
Liked 372 Times in 130 Posts
BEFORE:
AFTER:
^^ Day-Yum !
Nice. I have my turbo header right under the inlet tube to the throttle body.
I wonder if that will reduce the heat coming from the header?
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
