My Moser has been fine for five years.
Ed Wright 4156 SS/JA |
Liked 216 Times in 77 Posts
I have two of each (1 each in race cars and 1 each in street cars). The only difference between the two is Strange uses what looks like a factory shock/lower control arm bracket. And Moser uses a piece that they make in house. The Strange units have through bolts that hold the torque arm on and the Moser units use 4 short bolts. I have had good luck and zero failures with both brands. The only thing I would suggest is that if you go with the Strange unit tell them you want it set up for the Ford Axle bearing instead of the tapered bearing that they sometimes use.
Liked 786 Times in 210 Posts
Strange pays for "Perfectly Strange" Money at Nat Meets.
"Pistol" Pete Dutko |
Liked 20 Times in 3 Posts
I don't think you can go wrong with either one and one isn't going to be any better than the other. I have a Strange I ordered complete with brakes and have had zero problems. I will say that I ordered it from Edmond Richardson and he was cheaper than anyone else. You can get one from him as well.
Liked 920 Times in 259 Posts
We've used Strange. Happy with them. Fit, finish, gear set up has been spot on. No reason to try anything else.
Oh, I thought you meant an F body MoPar. Silly me. Jim
Jim Wahl....NHRA #2239 S/SS - IHRA # 8 Stock, D2 Stock Champion (forever I guess) 2019 Baby Gators Stock Champion 2009 NHRA D2 National Open Stock Champion 1982 NHRA D2 West Palm Beach LDRS SS Runner Up Past President, Southern Stock / Super Stock Association. ![]() |
Liked 685 Times in 204 Posts
I used a KTRE when I built my Camaro, I think that is what Mark Williams now sells. The problem I had with the 4 short bolts that held the torque arm was the bolts would loosen up on me all the time. I feel that the Mark Williams components are the best on the market. Dyno
