Old 07-18-2013, 11:47 PM   #1
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
Default F-Body Housing - Which to use???
Will be purchasing a 12 bolt for 97 Camaro stocker in the near future. My choices are Strange or Moser, as I'll be passing through illinois I will be getting one on the way. Is there a preference between the two? Thanks
Chris Chapman
1969 Chevelle
NHRA F-G/SA 1090
Old 07-18-2013, 11:58 PM   #2
Chad Rhodes
Default Re: F-Body Housing - Which to use???
No issues with my moser, and they are big time sportsman racing supporters
Chad Rhodes 2113 I/SA
Old 07-19-2013, 07:57 AM   #3
Ed Wright
Ed Wright's Avatar
My Moser has been fine for five years.
Ed Wright 4156 SS/JA
Old 07-19-2013, 01:29 PM   #4
Rob Petrie E395
Liked 216 Times in 77 Posts
I have two of each (1 each in race cars and 1 each in street cars). The only difference between the two is Strange uses what looks like a factory shock/lower control arm bracket. And Moser uses a piece that they make in house. The Strange units have through bolts that hold the torque arm on and the Moser units use 4 short bolts. I have had good luck and zero failures with both brands. The only thing I would suggest is that if you go with the Strange unit tell them you want it set up for the Ford Axle bearing instead of the tapered bearing that they sometimes use.
Old 07-19-2013, 03:00 PM   #5
Pistol Pete
Pistol Pete's Avatar
Liked 795 Times in 210 Posts
Strange pays for "Perfectly Strange" Money at Nat Meets.
"Pistol" Pete Dutko
Pistol Pete is online now   Reply With Quote
Old 07-19-2013, 07:22 PM   #6
K Stubbs
Liked 20 Times in 3 Posts
I don't think you can go wrong with either one and one isn't going to be any better than the other. I have a Strange I ordered complete with brakes and have had zero problems. I will say that I ordered it from Edmond Richardson and he was cheaper than anyone else. You can get one from him as well.
K Stubbs is offline   Reply With Quote
Old 07-19-2013, 10:54 PM   #7
CMcAllister
Liked 920 Times in 259 Posts
We've used Strange. Happy with them. Fit, finish, gear set up has been spot on. No reason to try anything else.
Old 07-20-2013, 01:09 AM   #8
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Wink Re: F-Body Housing - Which to use???
Oh, I thought you meant an F body MoPar. Silly me. Jim
Old 07-22-2013, 04:44 PM   #9
Dyno
Dyno's Avatar
Liked 693 Times in 205 Posts
I used a KTRE when I built my Camaro, I think that is what Mark Williams now sells. The problem I had with the 4 short bolts that held the torque arm was the bolts would loosen up on me all the time. I feel that the Mark Williams components are the best on the market. Dyno
