Old 07-18-2013, 08:33 AM   #1
Tgreen3724
Default BBC Oil Pump Recommendations
Pulled the motor out after noticing drop in oil pressure and the rear main and one of the other mains were ate up. The rear main looks like it was starved of oil was on the verge of failure. We ran our current pump most of last year without issue but this year we only got about 10 - 15 runs on new bearings before I noticed drop in pressure.
Was hoping you guys could provide some opinions;
What pump do you guys like to run in a BBC?
What pressure range do you like to see?
Any help would be greatly appreciated.
Tgreen3724 is offline   Reply With Quote
Old 07-18-2013, 10:14 AM   #2
Ed Wright
Ed Wright's Avatar
Default Re: BBC Oil Pump Recommendations
Lack of oil has always been up front, last bearings to get oil, in my limited experience. I kinda doubt the pump is your problem.
Ed Wright 4156 SS/JA
Old 07-18-2013, 11:23 AM   #3
Wet mag the crank, check it for straightness, size, taper, and roundness.
Then check the main bores for size, roundness, and straightness.
Odds are you'll find something .
Old 07-18-2013, 11:32 AM   #4
Mark Lewis
Liked 207 Times in 44 Posts
What does the flange on the rear main brg look like?
Have you changed trans or converter?
Might have a thrust bearing problem instead of oil pump.
Mark Lewis is offline   Reply With Quote
Old 07-18-2013, 12:39 PM   #5
Ed Wright
Ed Wright's Avatar
^^^^ More likely.
Old 07-18-2013, 03:21 PM   #6
Tgreen3724
thrust bearing and rod bearins all look fine. One thing is the front of the main bearing (flange) was rubbed down to the copper, like the crank had pushed back toward the converter. Doesnt make sense because I thought typically the crank would push toward the front of the motor if any as a result of converter ballooning. Does this indicate anything in particular? Having crank magged and block checked for proper line hone.
Old 07-18-2013, 03:25 PM   #7
Tgreen3724
also converter and trans are same no change whatsoever.
Old 07-18-2013, 10:01 PM   #8
Liked 10,767 Times in 2,238 Posts
Take it across the "River" and let Jeff Taylor look at it and check it out, you will be head in the long run.
Old 07-19-2013, 07:58 AM   #9
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
I'd say good chance your crank is cracked and flexing,you said had about 15 runs on bearings,what was the old bearings like or was it first build?
Your on the right track checking crank and line bore
Mike Taylor 3601
Old 07-19-2013, 09:18 AM   #10
Tgreen3724
we took the whole thing apart this past winter and replaced the bearings. The bearings we took out looked flawless.
