Going on the western swing; however, our conversion & stacker are just under 80' combined. Cannot find a way to get a permit like we did for FL. Any suggestions?
Liked 699 Times in 202 Posts
You may not need to do anything check this site.
http://www.dot.ca.gov/hq/traffops/tr...torsports.html |
Hoping you're correct! When I read this earlier, I felt that RVs were not included, that only a true semi tractor was referenced. Our Haulmark is 43' w/o the hitch & the stacker has a 30' box, putting it at about 34'.
You must be a commercial vehicle. IFTA tag and DOT number. Must fill out logs. Stop at scales RV's cannot be over 65 feet. Some people take there chances. Some people get caught.
Tony Janes 7941 STK, SS |
Well I guess the rules were written only for the Pro's big rigs. I don't get why a conversion wouldn't be considered the same.
I have a friend who pulls a 26' boat (30' overall) behind his 45' Monaco and hasn't been stopped yet for being over lenght. I guess you can take a chance but you know with the money hungry government they will set up some sort of sting just to catch the other racers. |
Liked 333 Times in 180 Posts
might be worth a phone call to the California DMV and see what they say!!!!
Liked 805 Times in 341 Posts
My understanding is that at least going to Pomona there are routes and travel times that are safe and others that are not. Hopefully someone who knows will PM you with the information.
Good Luck! Bill |
Well, we're not commercial. No lettering on either entity, titled & plated as RV & trailer in IN. I've tried contacting the track, which has been an exercise in futility (sent email, no reply; tried calling, no answer, so I left voicemail; tried their "chat" function, was disconnected because they didn't respond). Talked with a racer at Joliet that got a ticket in CA, said it was $200. Hesitant to call their BWV, as I don't want to raise a red flag. Was advised to travel at night; however, I've never been to CA & really wanted to check out the scenery while driving... All we want to do is go to their state & stimulate their economy a bit, but not by paying a ticket!
Liked 10 Times in 6 Posts
Pig farmer, I think the other states go by lenght laws in your home state, are you legal in your home state, for rv plated vechicle? Tom
Tom Moock 5704 STK |
Liked 216 Times in 77 Posts
Over-Length Motorhomes
(Greater than 40' up to 45') DEFINITIONS Over-Length Motorhome: An over-length motorhome is a single-unit motorhome that is longer than 40 feet but not more than 45 feet. (Note: A vehicle combination, e.g. a motorhome towing a vehicle or trailer, may be up to 65 feet length. If the single-unit motorhome is 40 feet or less in length, the combination is not subject to the route restrictions for the over-length motorhome.) Motorhome: A motorhome is a noncommercial passenger vehicle defined in the California Vehicle Code (CVC) Section 465 as a "house car" and commonly referred to as a recreation vehicle. CVC 362 defines "house car" as "a motor vehicle originally designed, or permanently altered, and equipped for human habitation, or to which a camper has been permanently attached." A motorhome should not to be confused with a bus (CVC 233) or a tour bus (CVC 612), also called "motorcoach," which is used for commercial passenger transportation and requires a commercial driver license to operate. See also Public Utilities Code 5360-5379.5 and 226. BACKGROUND The basic California length law for vehicles is 40 feet unless specifically exempted. On October 9, 2001, Governor Davis signed Assembly Bill (AB) 67 which changed the California Vehicle Code (CVC) to allow motorhomes over 40 feet in length, up to 45 feet, on certain routes. Over-length motorhomes are allowed on interstates and on those State routes that can accommodate them. DRIVER LICENSE REQUIREMENTS The CVC requires a motorhome endorsement on a noncommercial class B driver license issued by the California Department of Motor Vehicles (DMV). The pertinent CVC sections are copied below under "Legal History." Application: Click on this DMV website for commercial vehicle licensing and scroll down to these three topics: "How to apply for a noncommercial driver license," "Requirements for a Noncommercial Class B driver permit," and "Requirements for a Noncommercial Class B driver license." The driver must pass a written and skills examination (i.e. a driving test), submit a specified medical form, and pay a $34 fee. You may use the on-line DMV booklet Recreational Vehicles & Trailers (DL-648) to prepare for the exam. The booklet may also be available at the local DMV field offices that test motorhomes. To set up an appointment, or locate a booklet, you may call DMV at 1-800-777-0133. The medical exam must be repeated every two years. The license is valid for approximately five years. Out-of-State Drivers: Non-residents visiting California may not operate an over-length motorhome unless in possession of an out-of-state driver license authorizing the operation of that vehicle. See CVC Section 12804.15(b)(2) which is also copied below under "Legal History." LEGAL ROUTES Access Routes: Over-length motorhomes may travel on virtually every State route EXCEPT those signed with a 30-foot kingpin-to-rear-axle (KPRA) advisory sign. This sign advises trucks with a KPRA of more than 30 feet not to use the route. There are also KPRA advisories signs with 32, 34, 36, and 38 feet. These advisories that are 32 feet and higher ALLOW over-length motorhomes to use the routes. See the advisory sign below. Advisory Route Indicates KPRA length advised In case the signs are not posted as intended, it is recommended that drivers also use the maps as described below. On-Line Map: See: http://www.dot.ca.gov/hq/traffops/tr...45-bus-map.htm. Click on the red numbers to open each regional map. Restricted Route List: An on-line list of route segments that restrict over-length motorhomes is at: http://www.dot.ca.gov/hq/traffops/tr...s-restrict.htm. The list includes beginning and ending post miles and intersecting streets or highways of each segment. Stopping for Services: Over-length motorhomes may exit the designated route for fuel, food, and lodging provided the access is safe, and provided the service is within one road mile of an "identified" exit. The exit must be identified to show that the service route has been evaluated and approved by State and local engineers. Currently, the only identification system for service exits is a "Service Access" sign, which is an "S" on the back of a truck, as illustrated below. These signs were intended for large trucks, and are located primarily on the interstates. Sign # G66-55 For more information on service access, see the web page Service Access Routes. City and County Access Roads: Caltrans has jurisdiction over State routes only. Over-length motorhomes are allowed on certain State routes, but not necessarily on local roads. Cities and counties have jurisdiction over local roads. To inquire about motorhome access on local roads, contact the appropriate city or county public works department. CHANGING ROUTE CLASSIFICATIONS To request that a road be opened up to over-length motorhomes, follow these instructions: State routes: Caltrans has already analyzed State routes for their ability to accommodate 45-foot motorhomes, which is the worst case over-length motorhomes. However, highway improvement projects that change the geometrics may justify a new evaluation. To inquire about a possible new access route, contact Caltrans Headquarters at (916) 654-5741 for referral to the appropriate Caltrans district staff. City and county roads: To request a city or county road evaluation for over-length motorhome access, contact the appropriate city or county public works department. If the city or county road intersects a State highway, Caltrans will also need to evaluate the exit and entrance ramps. LEGAL HISTORY Vehicle Length: The basic vehicle length limit in California is stated in the California Vehicle Code (CVC) Section 35400(a): "A vehicle may not exceed a length of 40 feet." Federal & State Law (Buses): In 1991, federal legislation allowed over-length buses on the interstates and "reasonable access" routes. This federal law was codifed in State law in the California Vehicle Code (CVC) Section 35400(b)(10)(A). Caltrans determined which State routes can accommodate the over-length buses and created the over-length bus network map. State Law (Motorhomes): On October 9, 2001, California Governor Davis signed Assembly Bill 67 which also legalized motorhomes over 40 feet in length, up to 45 feet, on certain routes in California. Those routes include the interstates, and the same State routes that already allowed over-length buses. AB 67 is on the website of the Legislative Counsel of California at this link: AB 67. AB 67 changed or added the CVC sections listed in the table below. These CVC sections are also copied below the table. Section Topic 2429.3 Outreach committee. 12804.9 (b)(2)(F) Class B driver license. 12804.10 Class B driver license. House car endorsement -- written exam, driving test, and medical exam. 12804.15 Nonresident requirements. Endorsement requirements, fees and license expiration date. 14100 (a) Administrative hearings. 35400 (b) (11) Route access. Service access. 2429.3 (Please use the link to the on-line CVC as this section is long and may not be relevant to most readers.) 12804.9 ... (b) In accordance with the following classifications, an applicant for a driver's license shall be required to submit to an examination appropriate to the type of motor vehicle or combination of vehicles the applicant desires a license to drive: ... (2) Class B includes the following: ... (F) A house car over 40 feet in length, excluding safety devices and safety bumpers. 12804.10 ... (b) Any person seeking to drive any house car over 40 feet in length, excluding safety devices and safety bumpers, shall obtain a noncommercial class B driver's license with house car endorsement as described in this subdivision. The applicant for that endorsement shall pass a specialized written examination and demonstrate the ability to exercise ordinary and reasonable control in operating that vehicle by driving it under the supervision of an examining officer. Upon satisfactory completion of the examination and demonstration, the applicant shall be issued a noncommercial class B driver's license with house car endorsement by the department. Upon application for an endorsement to operate this vehicle, and every two years thereafter, the applicant shall submit medical information on a form approved by the department. (Note: "Department" in this CVC section means the California Departmenet of Motor Vehicles.) 12804.15 (a) Notwithstanding Section 362, for purposes of this section "house car" means a vehicle described in subdivision (b) of Section 12804.10. (b) (1) Except as provided under paragraph (2), no person may operate a house car unless that person has in his or her possession a valid driver's license of the appropriate class and an endorsement thereto issued by the department to permit operation of the house car. (2) A nonresident may not operate a house car in this state unless that person is in possession of an out-of-state driver's license authorizing the operation of that vehicle. (c) An endorsement to drive a house car may be issued only if the applicant meets all of the following conditions: (1) The applicant successfully completes an examination prescribed by the department to determine qualification for the endorsement. (2) Upon initial application and every two years thereafter, the applicant submits medical information on a form approved by the department to verify that the person meets the minimum medical requirements established by the department for operation of a house car. (3) Upon application for issuance of an original driver's license or renewal driver's license pursuant to subdivision (b) of Section 12804.10, there shall be paid to the department a fee of thirty-four dollars ($34) for a license that will expire on the applicant's fifth birthday following the date of the application. (d) The department may deny, suspend, or revoke an endorsement to drive a house car when the applicant does not meet any requirement for the issuance or retention of the endorsement. 14100. (a) Whenever the department has given notice, or has taken or proposes to take action under Section 12804.15, 13353, 13353.2, 13950, 13951, 13952, or 13953, the person receiving the notice or subject to the action may, within 10 days, demand a hearing which shall be granted, except as provided in Section 14101. 35400 ... (b) ... (11) (A) A house car of a length of up to 45 feet when operating on the National System of Interstate and Defense Highways or when using those portions of federal aid primary system highways that have been qualified by the United States Secretary of Transportation for that use, or when using routes appropriately identified by the Department of Transportation or local authorities, with respect to highways under their respective jurisdictions. (B) A house car described in subparagraph (A) may be operated on a highway that provides reasonable access to facilities for purposes limited to fuel, food, and lodging when that access is consistent with the safe operation of the vehicle and when the facility is within one road mile of identified points of ingress and egress to or from highways specified in subparagraph (A) for use by that vehicle. (C) As used in this paragraph and paragraph (10), "reasonable access" means access substantially similar to that authorized for combinations of vehicles pursuant to subdivision (c) of Section 35401.5. (D) Any access route established by a local authority pursuant to subdivision (d) of Section 35401.5 is open for access by a house car of a length of up to 45 feet. In addition, local authorities may establish a process whereby access to services by house cars of a length of up to 45 feet may be applied for upon a route not previously established as an access route. The denial of a request for access to services shall be only on the basis of safety and an engineering analysis of the proposed access route. In lieu of processing an access application, local authorities, with respect to highways under their jurisdiction, may provide signing, mapping, or a listing of highways, as necessary, to indicate the use of these specific routes by a house car of a length of up to 45 feet. ORGANIZATIONS The following trade organizations may be good sources of information. Family Motor Coach Association 8291 Clough Pike Cincinnati, OH 45244 (800) 543-3622 (513) 474-3622 Website: www.fmca.com Recreation Vehicle Industry Association 1896 Preston White Drive P.O. Box 2999 Reston, VA 22090-0999 (703) 620-6003 Website: www.rvia.org RV/MH Heritage Foundation 801 Benham Ave. Elkhart, IN 46516 (800) 378-8694 (219) 293-2344 E-mail: rvmhhall@aol.com Website: www.rv-mh-hall-of-fame.org California Association of RV Parks & Campgrounds P. O. Box 5648 Auburn, CA 95604 (530) 885-1624 E-mail: info@calarvc.com Website: www.camp-california.com National RV Dealers Association 3930 University Drive Fairfax, VA 22030-2515 (703) 591-7130 E-mail: info@rvda.org Website: www.rvda.org California RV Dealers Association 1401 P Street, #412 Sacramento, CA 95814 (916) 658-0260 E-mail: CalRVDA@aol.com The Good Sam Club P.O. Box 6888 Englewood, CO 80155-6888 Website: www.goodsamclub.com -------------------------------------------------------------------------------- CONTACTS Caltrans Legal Truck Size & Weight Work Group Casey Robb Manuel Fonseca General number (916) 654-5741 E-mail: Truck Size & Weight Unit. Return to the Caltrans "Office of Truck Services" page. Revised 3/14/12. |
