Old 08-28-2007, 12:52 AM   #2
Jeff Lee
Jeff Lee's Avatar
Default Re: 1969 Nova E/SA NHRA Stocker
Originally Posted by Grant Eldridge View Post
Update on E/SA Nova- I've had the motor out and checked it over, adding the following:- I've added coated Calico main bearings, shimmed the valve springs back to spec, replaced a few rocker arms as required, changed camshaft and freshened converter, increasing stall slightly, freshened the Schubeck internals and welded additional baffling inside the oil pan for hard launches. Ran car in combo yesterday, 11.83, 11.84 in E/SA , 3570 lbs. with 1300' air at Mission. If I can finish season here, will reduce price to $32,000. Last race will be end of September, can also consider selling as roller, or with some different parts at lower price. This car would sell locally for $25,000. set up for the street! You could not dream of building it this nice for this price to go this fast.......
I suspect your 11.83 & 11.84 times are mis-prints?
Jeff Lee 7494 D/S '70 AMX
