Old 08-27-2007, 05:47 PM   #1
LNorton
LNorton's Avatar
Liked 4 Times in 2 Posts
Default Re: Turbo-Action E-Shift Controller
As for the safety factor, if you are scared to pull the shifter with the front end hung up.... then you shouldn't be driving a car that hangs the front tires that high.
Stock is supposed to be STOCK! I'm falling in with Beard here. If you want the car to shift itself, get rid of the manual valve body, or use the factory computer to do your deed.
If you guys all get to have the e-shift, then I want all the stick cars to be able to have clutchless transmissions. Fair enough right!
Just another "enhancement" for our future.
Lee Norton - N229 STK
IHRA H/FIA - NHRA O/SA
RacerTees.com
LNorton is offline   Reply With Quote
