Old 05-21-2013, 08:22 AM   #101
Chuck Garey
Liked 10 Times in 7 Posts
Cool Re: Racer Suspension
I find it interesting that alot of us get on planes everyday that are 20 years or older (and private planes even older) with belts that are deemed comepletely safe by FAA but NHRA makes us change every 2 years.
Chuck Garey is offline   Reply With Quote
Old 05-21-2013, 09:19 AM   #102
SSDiv6
Liked 1,593 Times in 583 Posts
Default Re: Racer Suspension
The Boeing 777 has an inspection interval of 12000 hours of operation for seat belts. This is only an inspection, not replacement. It is subjective; you inspect the belts and if they look, appear worn or frayed, or the mechanism does not work, then they are replaced.
Old 05-21-2013, 11:10 AM   #103
jmcarter
jmcarter's Avatar
Liked 3,195 Times in 976 Posts
And this is from a industry that puts safety as the #1 priority. Having worked in that industry for over 30 years and having experience with SCCA and other sanctioning bodies I think many of the NHRA safety rules are arbitrary window dressing that defy common sense and dumb down tech inspection (no disrespect to the great tech folks). They send hand grenades down the track and make small incremental safety steps and have failed to develop a tire/wheel tether system or body integrity systems that would keep flopper bodies out of the spectator areas. Biggest safety advance they could make would be to roll back 40 years and institute the Big Daddy rules package (I.e.starts at the end of a run or you are disqualified). They'd get bigger fields in the PRO's and take less time to run, make track prep equal for everyone as well. Instead they enforce non-sensical rules like the belts which chafe at all the sportsmen racers, not all of whom have 500K operations. Wonder how long dragster racers lobbied for a secondary hand brake? Too long....
All that said, it's their rules so if you want to play on their sandlot then it is what it is.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 05-21-2013, 12:07 PM   #104
Ed Wright
Ed Wright's Avatar
NHRA is simply requiring repeat business for companies in return for their sponsorship, right?
Ed Wright 4156 SS/JA
Old 05-21-2013, 12:53 PM   #105
SSDiv6
Especially when Carl Olson, former NHRA VP, is the Motorsports Manager at SFI...
Old 05-21-2013, 10:10 PM   #106
Doug Blackley
Doug Blackley's Avatar
Originally Posted by Dan Bernay View Post
Wasn't this tread about seatbelts?
You didn't get the change of topic memo? LOL
Doug Blackley 1697 STK
Old 05-22-2013, 07:32 AM   #107
Pedigo Perf
Pedigo Perf's Avatar
Liked 30 Times in 17 Posts
Sorry, I am only in my early fifties. What does this "starts at the end of a run" mean?
Pedigo Perf is offline   Reply With Quote
Old 05-22-2013, 08:01 AM   #108
jmcarter
jmcarter's Avatar
Big advocated a rules package that included at the end of a run the fuel cars should be able to restart and run. If they couldn't they would be disqualified. He had a well thought out proposal to control cost and improve the racing but guys like Bernstein advocated the go fast approach that requires mega sponsorship $$$ to field a car. The DSR/JFR circus is the result.....
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 05-22-2013, 08:11 AM   #109
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
means that car would have to be able to start and run at end of track,nitro cars.
Big Daddy thought it would be good,cut back on oil downs and keep guys from leaning on stuff so hard they blew up every pass.
Mike Taylor 3601
I type way too slow
Old 05-22-2013, 08:55 AM   #110
Painter
Liked 162 Times in 45 Posts
Maybe another magneto and a bigger fuel pump would help you're typing speed! Lol
Painter is offline   Reply With Quote
