Old 04-11-2013, 10:53 PM   #1
astikhossw
astikhossw's Avatar
Liked 20 Times in 9 Posts
Default pushrod and spring replacement
When do you guys know when to replace pushrods and springs.I had some problems with my motor and none of the pushrods are bent but the tips are shiny,and the springs went from 220# to 190# i have replaced the springs but not sure about the pushrods.Thanks
astikhossw is offline   Reply With Quote
Old 04-13-2013, 01:24 AM   #2
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
Default Re: pushrod and spring replacement
Probaly just wore through black oxide coating as long as tips are smooth and not wore,usaully pushrod will show wear around edges of oil hole will look like it's chipping along edge of oil hole when it's wore.
Just guessing you are describing coating wore off which is normal
Mike Taylor 3601
Old 04-13-2013, 10:28 AM   #3
astikhossw
astikhossw's Avatar
Thanks Mike it looks as if they need to be replaced the holes looks like what you described.
