#11 |
Looking for input regarding Martin Diesel and Next Gen diesel generators? Pros and cons for both would be appreciated. They are going to be used in an ambulance as a back up power source to an inverter. We are currently using Martin Diesel and our ambulance builder is recommending Next Gen for some new ambulances we are having built. Thanks in advance.
Joe Martens AA/Stock 3969 |
#12 |
Liked 544 Times in 213 Posts
Joe I am not familiar with either brand name generator you mentioned. So I could not give you any info on one....
Onan is by far the most common generator we get in for service or see for repairs. I have worked on many of them that were installed in emergency response type vehicles. Diesels usually.... We have occasionally seen PowerTechs and I have worked on quite a few of those as well. Tom thanks for the recommendation. See you soon.....Rich
#13 |
Liked 216 Times in 77 Posts
Cummins Onan RV QD 10000
Is there anywhere I could find out how much fuel they should be using? And how many hours should they be run before servicing (oil, filters ect)? Thanks |
#14 |
Sponsor
Oil and filter is 250 hours, fuel and air filters at 500 hrs.
My experience is that might be a bit too much, I go 200 and 400 respectively. Fuel consumption will vary depending on how much load is on the engine, so the factory guide lists this: No load = .11 GPH (gallons per hour) 1/2 load = .48 GPH Full load = 1.01 GPH Hope that helps....
Matt Schurman |
#15 |
Thank You.
#16 | |
#17 |
Liked 275 Times in 76 Posts
Rob,
Does the generator sound like it has a load on it? Do you have access to a amp meter to measure the load at each circuit breaker? It sounds like there is a load on it from something else, other than what you have described. You could turn off circuit breakers one at a time and listen for the generator to unload, if something is drawing from it. I can run my A/C and everything in the trailer for close to 20hrs continuously on 15 gallons. I have a Onan Marquis Gold 7500. Good Luck Sean
#18 | |
#19 |
Rob,
Have you had any luck with the generator? A few weeks ago I measured what mine burned in one day. This was with A/C running, fans, computers, tv, battery charger and 110 vac pump and chiller running for 8 hrs straight. 7 gallons. It surprised me that it did not use more fuel than that. Sean
#20 |
Guest
Posts: n/a
We just purchased our first RV; also have never owned a generator. The motorhome is a 2007 Jayco Greyhawk 31SS with an Onan 4000. The generator has 800 hours on it but the RV only had 9,000 miles. Upon delivery (when we got home) even though we tested everything the generator would start fine, run for 5 minutes, and then die. The dealership put a new carburetor AND fuel pump on it at no charge to us. Seems to run perfectly now.
We plan, of course, to change oil regularly and use it a little more (I've read it's bad to let them sit) but my question is how many hours can I expect out of this generator before it needs replaced or major service? Thanks. Wendy & Scott |
