Why? Might try running it a little cooler. May find a little ET. Mine likes to leave about 90 degrees.
Ed Wright 4156 SS/JA |
Liked 184 Times in 113 Posts
For Mufflers..I like Spintech the best ..
Enjoy that my ears are not ringing at the end of the day.! BTW my car still has working AC and love cooling down a bit after a run ![]() D |
#3 | |
Liked 369 Times in 127 Posts
"The dreaded blowmaster drone..." lol
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
#4 | |
Are you running racing fuel ? I might experiment with the lower temps. Not sure how it will work with a 9 to 1 engine on unleaded pump gas. Alot of the reason I run at those temps are for round robin (consistency) purposes. Easier to get the water temp down to 160 than it is 90 degrees between rounds. I'm still using the OEM computer and sensors even tho the IHRA rulebook does not say a racer cannot run an aftermarket ECM. ( if I read that correctly) All I did on my car was set the dizzy and leave out the spout connector so the timing is locked @ 32 deg.
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT Last edited by ALMACK; 03-21-2013 at 12:20 PM. |
#5 | |
That GM car has a plug-in chip. Uses the stock ECM. I can/have made stock looking chips for limited classes that don't allow chips. LOL
Liked 166 Times in 71 Posts
the tbi engine such as 305 can run with the timing connector unplugged to run at a base timing too. unlpug it and set the timing to 32-34 at the track, set back to 0-4 and plug in for the drive home
Liked 70 Times in 29 Posts
do those cars have an adjustable fuel pressure regulator on them?
Chris Bowman The Mountain State Mustang 1984 Mustang GT350 |
#8 | |
"Do they have adjustable fuel pressure regulators?" No, but they can be made adjustable. Sure crude-azzed ways to try to tune one. Lmao!
Got headers and mufflers on yesterday and going to change oil to synthetic. Hopefully this will pick me up some.
my 88 monte ss is retired from pure stock but still will run 8.7s all day let me know how your coming out. that tbi motor runs way lean to begin with(hope you got a better fpr). I put one on my 87 suburban and it ran a lot better 3800lbs 10.30 1/8 mile and 20 mpg with 3.08's.
