I put a 3.42 rear gear and a posi unit
Liked 184 Times in 113 Posts
Liked 70 Times in 29 Posts
I would go with at least a 4:10 or 4:30. With the OD trans, those gears would be fine unless you plans to drive long distances on the street. your 3:42 is not nearly enough gear for the strip.
Chris Bowman The Mountain State Mustang 1984 Mustang GT350 |
#4 | |
It uses a 4.10 with 26 inch tall tires for racing. Change to near 28 inch tall street tires to drive home on. With the 4L60E tranny get near 20 mpg cruising home. If you Trailer 4.56 with 28 inch tall slick works. D |
Liked 369 Times in 127 Posts
^^ Good suggestions so far.
-160 deg. thermostat - as deep of a rear gear as resonable to cruise on the road with - minimum weight to fit class - lots of air pressure in the front tires - short belt to bypass the power steering (or remove PS altogether) - aftermarket headers and an x pipe (must run mufflers that are not "see through"
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
Liked 50 Times in 28 Posts
What e.t.'s are you running now? What horsepower is your motor?
#7 | |
You can not band aid around that. Also timing it foot braking from a low RPM. Turn the distributor far enough to make them leave like that, and it's over-advanced at higher RPM. You have to change the curve. Just the washer part of a thermostat would be better than a 160. Do you race your car at 160? Probably not if it has an iron block.
Ed Wright 4156 SS/JA |
#8 | |
160 in the burnout box. 170 when the car is fully staged. 180 at the end of the run. all on 93 Unleaded
Headers are on the way. Ordered some headman headers and got some flowmasters to go on it.
The car has run a best of 9.72. But other than that one time it runs 9.85s. and it is a 170HP 305
