Old 03-04-2013, 05:25 PM   #1
tony5022
tony5022's Avatar
Liked 10 Times in 2 Posts
Default Re: Help any input will be welcome
Not sure if this is the same on a wide tire car but on my 9" tire if we do not have enough air pressure and the front end is loose we hit the tire so hard when I let the clutch out it kills the wheel speed and bogs the motor bad. We had a few still shots taken of the car and the tire was down to the rim then rolled over itself. My holley combo overcame that pretty fast but my WCFB will die until 2nd gear then run great. Just a thought.
tony5022 is offline   Reply With Quote
