Old 03-03-2013, 11:41 PM   #1
1965
Default oil line
looking for a replace my copper oil line that keeps breaking down at fitting does anybody know if they make a stainless braided line that small
1965 is offline   Reply With Quote
Old 03-03-2013, 11:50 PM   #2
Default Re: oil line
Autometer makes a "fast response" kit for their oil pressure gauges, it is a -4 stainless steel braided hose with various fittings.
Old 03-04-2013, 12:29 AM   #3
Rory McNeil
Liked 1,104 Times in 302 Posts
Just curious why your copper tubing is breaking. Do you have a loop close to the engines oil pressure fitting? I have had the same 1/8 " copper tubing on my Stocker for 10 years, and 3/16" copper tubing on my bracket car for 25 years, never had a crack, leak, or any other issue.
NHRA 6390 STK
M/S 85 Mustang
Old 03-04-2013, 08:30 AM   #4
Ed Wright
Ed Wright's Avatar
I don't trust copper or plastic tubing. I always use -4 braided hose.
Ed Wright 4156 SS/JA
Old 03-04-2013, 10:20 PM   #5
1965
thanks for the responses
dont know why it comes out of fitting up motor thru firewall but i think i will find fittings to replace with #4 braided line thanks again
Old 03-05-2013, 09:29 AM   #6
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
I like to use a bulkhead fitting somewhere on the firewall.
that way I can use a short hose from the engine to the firewall and disconnect it at the firewall .
Makes it a lot easier than disconnecting at the engine on some cars.
Old 03-05-2013, 09:33 AM   #7
Keith 944
Keith 944's Avatar
Liked 1,884 Times in 578 Posts
that's a great idea tom. i just struggled with tightening the nut on my fitting at the rear of the block. i am going to use this suggestion. will be WAY easier
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 03-05-2013, 02:14 PM   #8
Ed Wright
Ed Wright's Avatar
That's how I do it. I have a 90 deg hose end under the hood, at the firewall. I put the engine in with that short hose connected to the engine. When you get old and arthritic it's easier to screw that 90 deg hose end to the firewall than the other end to the fitting on the engine. LOL
