Old 03-02-2013, 11:43 PM   #1
SuperStockDodge
SuperStockDodge's Avatar
Thumbs up Re: Kyle Ratcliff to drive Jet Car at Houston
Congratulations on your maiden voyage tonight! I like how many times you hit the "after"burner, "before" the run! Did all that heat generated on the run melt the E-shift solenoid? Also, will tear down be tomorrow since you set a new record in Jet Car/AH? If so, will you need extra valve cover bolts to go back together? Also, when will you be available for autograph signing?
Sean Fischer 5864 SS/E
SuperStockDodge is offline   Reply With Quote
