Old 02-25-2013, 09:43 PM   #3
art leong
Default Re: Little Torqueflight 2 to 3 shift?
Originally Posted by Alan Roehrich View Post
If it has a 3rd gear accumulator, put a stiffer spring in it, or block it off. Either will make 3rd gear apply faster. You'll have to make sure it does not apply fast enough to bind up.
I don't think it uses a third gear accumulator. I believe the band is used in second gear it releases and the high gear clutch pack applies, when you shirt into third
Art Leong 2095 SS
