Old 08-06-2007, 08:15 PM   #3
Arnold Greene
Liked 3 Times in 2 Posts
Default Re: Please Help Me Get This Thing To Hook Again!
Eric, if your rear spring eye o.d. is against the frame rail, it will not allow the spring to work. Either your car is sitting too low, the springs are too long, or your shackles are too short. Are the shackles leaning forward or to the rear? Are they stock or aftermarket? Also, the slide-a-link works better with near '0' pinion angle. Three degrees would work if you had slapper bars. Hope this helps.
Arnold Greene
IHRA/NHRA 2420 A/S, B/S
Arnold Greene is offline   Reply With Quote
